scott52 Member 188 Member For: 22y 6m 14d Gender: Male Location: Perth, W.A. Posted 24/12/02 03:05 PM Share Posted 24/12/02 03:05 PM I took delivery of my new XR6T on the 13 December and have been looking under the bonnet ever since. The hose running from the pressure side of the air pump over to the waste gate passes through an electric valve or switch of some sort. This switch is mounted to the side behind the battery and is hard to get your hand to because of the turbo hoses. The point is, the switch has a two prong connector that is not connected to anything! :o On closer inspection, tucked away and taped back to the wiring harness is the section of wiring that obviously plugs into this switch. Why would Ford not connect this switch to the wiring harness? I plugged it in to see what happens. I don't think it made any difference, but my son reckons the turbo makes more noise with the the wire pugged in. Any body got any answers or is mine the only one ex factory that is not connected? Also has any body fitted a boost gauge yet? I'm going to put one in just to see what is going on. I was going to put a tee piece into the wastegate hose mentioned above and connect the boost gauge hose into that. Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/ Share on other sites More sharing options...
CJF077 The Noble Leader Administrator 4,786 Member For: 22y 8m 26d Gender: Male Location: Sydney Australia Posted 24/12/02 09:33 PM Share Posted 24/12/02 09:33 PM Ill take a look at mine later.. dont think im going to ruin the interior with gauges on this one.. the car is way too nice.. Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4146 Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 8m 28d Gender: Male Location: Outer east - Melbourne Posted 25/12/02 01:24 AM Share Posted 25/12/02 01:24 AM The hose running from the pressure side of the air pump over to the waste gate passes through an electric valve or switch of some sort. This switch is mounted to the side behind the battery and is hard to get your hand to because of the turbo hoses. The point is, the switch has a two prong connector that is not connected to anything! :o On closer inspection, tucked away and taped back to the wiring harness is the section of wiring that obviously plugs into this switch. Why would Ford not connect this switch to the wiring harness? I plugged it in to see what happens. I don't think it made any difference, but my son reckons the turbo makes more noise with the the wire pugged in. Any body got any answers or is mine the only one ex factory that is not connected? Get your hands on the service manual. There should be an electrical diagram in there. It may give you some clues Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4152 Share on other sites More sharing options...
Mals BA XR6T Member 381 Member For: 22y 7m 5d Location: Sydney Posted 25/12/02 10:26 AM Share Posted 25/12/02 10:26 AM The point is, the switch has a two prong connector that is not connected to anything! On closer inspection, tucked away and taped back to the wiring harness is the section of wiring that obviously plugs into this switch. Why would Ford not connect this switch to the wiring harness? I plugged it in to see what happens.Ok son, there is this big red button next to that complicated machine.... while I'm gone do not push it... :lol: :lol: Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4173 Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 8m 28d Gender: Male Location: Outer east - Melbourne Posted 25/12/02 12:44 PM Share Posted 25/12/02 12:44 PM Ok son, there is this big red button next to that complicated machine.... while I'm gone do not push it... :lol: :lol: What's this button do........ Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4184 Share on other sites More sharing options...
scott52 Member 188 Member For: 22y 6m 14d Gender: Male Location: Perth, W.A. Posted 26/12/02 01:49 AM Author Share Posted 26/12/02 01:49 AM Reminds me of the Chief saying to Max Smart - - "Remember Max don't pull that lever......"I can't see any control on the boost pressure other than the standard method of running a hose from the pressure side of the airpump to the wastegate controller. Boost pressure acts against a spring until it overcomes the preset spring pressure and the wastegate starts to open. There is the valve or switch that I found that connects to the EMS (I presume), but that has been disconnected as I said before. Have you had a look at yours yet CJF077? It looks to me like a bleed valve, or pressure regulator of some sort in the hose would increase the boost pressure, however there must be a sensor somewhere that measures that pressure and tells the EMS. Where is it? Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4203 Share on other sites More sharing options...
CJF077 The Noble Leader Administrator 4,786 Member For: 22y 8m 26d Gender: Male Location: Sydney Australia Posted 26/12/02 05:39 AM Share Posted 26/12/02 05:39 AM Scott52 what am i supposed to be looking for? i tried looking for what you mentioned but couldnt find anything Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4216 Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 8m 28d Gender: Male Location: Outer east - Melbourne Posted 26/12/02 05:54 AM Share Posted 26/12/02 05:54 AM Scott52 what am I supposed to be looking for? I tried looking for what you mentioned but couldnt find anything Perhaps Scott52 could post a pic fpr all to see? Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4222 Share on other sites More sharing options...
PSI40L Member 175 Member For: 22y 6m 21d Posted 26/12/02 06:37 AM Share Posted 26/12/02 06:37 AM The switch that u r talking of here is merely a temperature sender switch ive taken the whole switch out and had a look at it and had it confirmed also with what it is if u disconnect the car still runs no problem there are no pressure gauges in the car an easy place to get presseur is to put a tT piece that goes to blow off valve u cant miss it it is there that where I got mine from Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4235 Share on other sites More sharing options...
richdave SLOJAM, Gone but not forgotten Lifetime Members 1,841 Member For: 22y 8m 28d Gender: Male Location: Outer east - Melbourne Posted 26/12/02 08:41 AM Share Posted 26/12/02 08:41 AM The switch that u r talking of here is merely a temperature sender switch ive taken the whole switch out and had a look at it and had it confirmed... So why would Ford install a temperature sender and then not use it Link to comment https://www.fordxr6turbo.com/forum/topic/443-modifications/#findComment-4241 Share on other sites More sharing options...
