  • Member For: 18y 4m 29d
Searched, and found plenty of info, but not really what I was after.
I want to get the Fully Hectic noise just for sh*ts and giggles till my APS stuff arrives.
Is it as simple as clamping that little hose that comes off it in the middle, can I unplug one end of it and jam a screw in there, if so , what end?
OR do I remove the BOV all together and plug the holes up with the 1 inch chair leg stoppers, I bought some today.
Anyone able to give me some detailed instructions on how to do this without busting something?
https://www.fordxr6turbo.com/forum/topic/43918-bypassing-bov-on-f6/
  • Replies 24
  • Member For: 18y 1m 16d
:slap:
Sorry mate but I think this is about the 8th one today.
You might as well take the whole thing out and plug up all the holes with your stoppers, or for a different sound you could vent the bov.
Just to let you know, its the stock item, car is completely stock apart from K&N at this stage.
Do I remove the cross over pipes remove the BOV completely, plug the holes that are left open and that's it? What about that little hose, I think it's called the vacuum hose. As you can tell.. I don't know too much about these things. Venting the BOV, what would that require, I went through the other thread in here but, it still doesn't make much sense to me.
I don't think you will get much flutter if you remove the bov running a stock setup and boost. Give me a few minutes then look in the bov section.
All done.
Edited by XRTPSI
  • role model
  • Member For: 19y 4m 2d
you will only just get flutter noise if you do it that way, not a dose.
still sound good though. not hard to do mate pull the crossover off and
block the BOV up and put back together ahha.
read XRTPSI thread everythnig you need to know.
  • Member For: 18y 2m 26d
It will not be loud but it will go off few times (I like the sound it makes), just take the small vacuum hose off the bov and put a screw in to it. No need to take the bov off if you will change everything soon anyway. It's too much hassle and no real benefit. Taking the hose off and putting a screw in to it takes about 2 minutes, and you can put it back to standard in 2 minutes again if you don't like it.
  • You are a dead set goose
  • Member For: 19y 7m 12d
I might see how that works lol
Which one is the vacuum hose? (me stoopid too)
