  • Legacy Donating Member
  • Member For: 22y 7m 2d
Posted
It is 4 bolts and a plug
Stick your head under the car and you should see 2 bolts on each side holding the bar to the chassis.
There is also a plug for the loom that goes throught a grommet on the right side into the boot.
I can only speak from removal of the Ford 1800kg bar, but I would imagin it is similar.
I used a rattlegun to remove the bolts as they should be threadlocked in place if it has been installed properly.
  • Member For: 18y 7m 25d
Posted
thank you very much mate
