xf_turbo Member 45 Member For: 19y 7m 18d Gender: Male Location: Adelaide Posted 17/01/08 07:19 AM Posted 17/01/08 07:19 AM Hi everyone,I've been reading the thread about factory sub replacement and decided to give my stereo in the T a small upgrade. I only have the basic sound system which leaves me behind the 8 ball to start with but so far I have installed Clarion 5 x 7's in the back. I have bought the JBL GTO 804 8" sub today. So that can go in the factory hole in the parcel shelf. I've been searching eBay for an amp and found this one but the specs dont mean a whole deal to me so I was hoping you guys would be able to explain it to me or just let me know if it will do the job. Any help would be greatIts a 2nd hand Kenwood 4 ch, specs from kenwood site are below.The sub as most of you would already know is 200w RMS 4 ohm impedance and the Clarion 5 x 7s are 150wSo Would this amp be powerfull enough to run the sub and the two rears? I'm not after anything ear drum popping just want a bit more bass and a nice factory look.eBay Item Number : 220191485496Thanks,JOELKAC-746 4-Channel Power Amplifier Max. power output 70W X 4 (4Q) 35W x 4 at 4Q 14.4V (0.08% THD) RMS power output - 50W X 4 at 1Q 14.4V (0.8% THD) RMS power output Variable input sensitivity (0.15 to 4V) Built in Variable Low-pass filter (50Hz - 20QHz) Built in Variable High-pass filter (50Hz - 200Hz) Gold Plated Input / Output Terminal Tri-mode operation Protection Indicator Power MOSFET Switching Power Supply
RAP1D Member Legacy Donating Member 3,739 Member For: 20y 4m 8d Gender: Male Location: Sydney NSW Posted 17/01/08 08:42 AM Posted 17/01/08 08:42 AM Yep, those older Kenwoods are pretty good, honest amps.I dont know much about the basic sound system so I cant comment in instalation.. ie wiring the amp in
