Zf6 Input Shafts
Featured Replies
#1
Have been reading that some cars have been twisting input shafts on these boxes and that a newer (improved) heat treated item is now available. Is there a build date for cars for this uprated/improved item? What will the old one take before it shows signs of distress and temporarily curtails the search for more power? Are there any other weaknesses that increased power levels have shown with this box?
#2
I spoke with ZF australia about a new updated input shaft, they say it has not changed still the same
I know Kewish automatics in vic strengthen the shafts and also beef up the clutch packs with extra clutches
#3
extra clutches! the thing already has triple clutch packs in it! must be getting pretty cramped in that bell housing!
#4
The piston in the clutch hub needs to be machined down and the top pressure plate thickness has to be altered to take the extra clutches
#5
Sounds pricey? Ever heard costs?
Does it change the feel and shift characteristics of the box?
Felix
#6
U would have to speak with kewish regarding pricing
Shifts are quicker, sharper, firmer
#7
ZF won’t admit to the shaft problem or a new heat treated one they NOW sell. Simply buy a new input shaft (1068 271 097) and compare. $360.00
I doubt Kewish are doing anything to the shafts apart from buying the latest heat treated one.
The “E” clutch pack (4th, 5th, and 6th gears) is the weakest link and you can increase the number of Frictions Discs and plates from 6 to eight which is cheap as chips. I actually increase the Friction discs in mine in “A’ ‘B’ & ‘E” packs>>>>> 6, 6 & 8 respectively. From 5, 5 and 6.
#8
Thanks for the info :buttrock:
Did u do any mods to the valve body?
Cheers
#9
Nope. Not untill I can be 100% sure the input shaft is strong enough to cope or BANG another one !!!! Being individual clutch modulation it is easy to attack each one but not just yet.
Actually just did Youngy's ZF today and put 7 Discs and plates in B pack and 8 in E so see how that goes with 400+++ Rwks .. Youngy will give it a workout and some!!!! :buttrock::secret:
#10
  • Author
Any ideas of fitment dates (re build dates) for the "new" item?
Recently Browsing 0
