BB. Member 69 Member For: 17y 7m 11d Gender: Male Location: Mildura Posted 14/12/07 10:02 PM Share Posted 14/12/07 10:02 PM Hey guys.Yesterday we pulled the tub of my ute (what a stuff around that is) and installed a Walbro Gss341 Fuel Pump. Now we tested everything without the tub on.. all was fine.. no surging.. started fine. After we put the tub on and I went to go home it started being a *beep* to start... sometimes taking 5 + seconds to start... but once its going it doesn't effect the performance of the ute at all.. just a pain in the ass to start... any of you guys had the same problem or know what it could be?cheers.BB Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/ Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 4m 6d Gender: Male Location: Not sure? Posted 14/12/07 11:33 PM Share Posted 14/12/07 11:33 PM Cos Dane helped you!!! Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609103 Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 11m 5d Gender: Male Location: Canberra ACT Posted 15/12/07 01:55 AM Share Posted 15/12/07 01:55 AM any chance you have pinched a fuel line putting the tub back on? So the pump is taking longer to get fuel pressure to the rail?You should be able to hear the Walbro whine a little when you first turn the key on before it starts? Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609152 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 10m 21d Gender: Male Posted 15/12/07 02:41 AM Share Posted 15/12/07 02:41 AM a mate and I were going to do this during Jan.Its a couple hour job isn't it?Is it a matter of just taking out the tub liner and then you have access to the fuel tank? Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609171 Share on other sites More sharing options...
saleen Big Gun Donating Members 4,170 Member For: 22y 7m 1d Gender: Male Location: NSW Posted 15/12/07 02:47 AM Share Posted 15/12/07 02:47 AM Is it an auto? If so, move the selector to P Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609176 Share on other sites More sharing options...
SCRIBR Yaris member Member 4,486 Member For: 18y 10m 21d Gender: Male Posted 15/12/07 02:55 AM Share Posted 15/12/07 02:55 AM Is it an auto? If so, move the selector to PI hear that's a common problem with autos! Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609179 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 19y 10m 22d Location: Canberra Posted 15/12/07 03:02 AM Share Posted 15/12/07 03:02 AM when I had my XR it became hard to start after the walbro install. Especially if I had just driven it, stopped for a little while. Turns out it just needed a little extra time to build enough pressure or something, because if I turned the car to 'on' and let it sit for 10 or so seconds it would pretty much crank over straight away. See how that goes, and if it's still an issue.. I dunno! Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609183 Share on other sites More sharing options...
BB. Member 69 Member For: 17y 7m 11d Gender: Male Location: Mildura Posted 15/12/07 08:43 AM Author Share Posted 15/12/07 08:43 AM any chance you have pinched a fuel line putting the tub back on? So the pump is taking longer to get fuel pressure to the rail?You should be able to hear the Walbro whine a little when you first turn the key on before it starts?The pump primes as per normal. Is difficult to start and the pump is louder than 2 other utes I have heard with the same pump. But apparently its almost as loud as ENVY-T a mate and I were going to do this during Jan.Its a couple hour job isn't it?Is it a matter of just taking out the tub liner and then you have access to the fuel tank?Couple of hours if beers are not consumed and you don't stuff around.. the WHOLE tub has to be removed not just the liner.when I had my XR it became hard to start after the walbro install. Especially if I had just driven it, stopped for a little while. Turns out it just needed a little extra time to build enough pressure or something, because if I turned the car to 'on' and let it sit for 10 or so seconds it would pretty much crank over straight away. See how that goes, and if it's still an issue.. I dunno!Tried... didn't work... it takes atleast 5 seconds to start but every now and then it will take longer to start regardless of whether its hot or cold... any one else got any ideas... oh yeh.. I was running 3/4 a tank of petrol so that shouldn't be the reason why.. Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609288 Share on other sites More sharing options...
NATHOON Donating Members 197 Member For: 18y 9m 23d Gender: Male Location: Sydney Posted 15/12/07 09:05 AM Share Posted 15/12/07 09:05 AM What hose did you use Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609291 Share on other sites More sharing options...
BB. Member 69 Member For: 17y 7m 11d Gender: Male Location: Mildura Posted 15/12/07 10:31 AM Author Share Posted 15/12/07 10:31 AM (edited) What hose did you useFull braided teflon..... made up at enzed.EXACTLY the same as a mate is using in his ute with no dramas what so ever, after he had issues with the Gates submersable high pressure fuel hose splitting Edited 15/12/07 10:45 AM by BB. Link to comment https://www.fordxr6turbo.com/forum/topic/40598-ute-having-trouble-starting-after-walbro-install/#findComment-609307 Share on other sites More sharing options...
