11/12/07 02:06 AM11/12/07 02:06 AM #11 If its a heater coolant leak you'd know it. It reeks.More than likely a blocked drain.Run the car up on some ramps and have a look for a hole/hose near the transmission tunnel, roughly under the dash area. If you can run a piece of wire or electrical cable up and down it a few times, not too far, and get out the way. Better still if possible use compressed air, but not a full blast otherwise water will spray around the dash/electrics of the car.
11/12/07 11:38 AM11/12/07 11:38 AM #12 Its an easy fix but you will need some special tools:A long weightA tin of compressionTwo skyhooksSome rainbow coloured paintA set of metric adjustable spannersA left handed screwdriverand a tin of scotch mist you had better add a 6" snatch reamer to that list too
