Mr Man Mad Scientist Member 816 Member For: 20y 6m 30d Gender: Male Location: Vic Posted 20/10/07 10:54 AM Share Posted 20/10/07 10:54 AM I have the ba mk1 and didn't have to drill any holes just took a lot of patience to line them all up hav'n someone to help you hold things helps a lotyeah mine is mkii, I think they are slightly different, pretty sure it says something about it in the installation instructions?? Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-586674 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 14d Gender: Male Location: Nrth Qld Posted 20/10/07 10:58 AM Author Share Posted 20/10/07 10:58 AM (edited) Ive got Mk I so hopefully the drill shouldnt have to come out. Thanks for that pic to! Just gotta hope I have enough clearance between the I/C and my PWR trans cooler. The trans cooler is mounted to the radiator. Ive shifted it as far back toward the motor as possible so fingers crossed it will be ok......... Edited 20/10/07 11:12 AM by hanra Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-586676 Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 5m 22d Gender: Male Location: Not sure? Posted 20/10/07 12:08 PM Share Posted 20/10/07 12:08 PM A mate and I installed one the other weekend on MK1, and at the same time, fitted the PWR trans cooler to the radiator also, you should not have a problem.Good luck Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-586695 Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 10m 4d Location: Brissy Posted 20/10/07 12:35 PM Share Posted 20/10/07 12:35 PM (edited) Hope you work it out I bought a Monsta cooler which is supposedly a copy of the monza/wog cooler but it came as cooler only no brackets, instructions nothing, what brackets etc do you think I'll need to have made up?? any pics, of the brackets that came with yours? cheers Edited 20/10/07 12:43 PM by Paranormal Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-586700 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 14d Gender: Male Location: Nrth Qld Posted 21/10/07 01:49 AM Author Share Posted 21/10/07 01:49 AM Mine is a 2 dolla monsta jobby also. Mine came with brackets/bolts. Get onto em and get them to send you some. Here are the pics of the brackets I was supplied. Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-586810 Share on other sites More sharing options...
Paranormal Member 469 Member For: 21y 10m 4d Location: Brissy Posted 22/10/07 10:47 AM Share Posted 22/10/07 10:47 AM Cheers Hanra thanks for pics Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-587367 Share on other sites More sharing options...
hanra Into the laaaake Member 1,532 Member For: 18y 14d Gender: Male Location: Nrth Qld Posted 24/11/07 10:13 PM Author Share Posted 24/11/07 10:13 PM Righto I got this monst (monza style) intercooler off ebay for bugger all. Fitted it all up this on saturday. I made things difficult for myself due to the fact that I had fitted a PWR Aux trans cooler onto the A/C condensor. This made things very very very squeezy.... Main problem was that I mounted it as low as possible to allow clearance for the stock I/C. I also shifted the horns to underneath the drivers side guard, there was a hole already there for the mounting bolt and a big hole for the wiring!!! Perfect. So I ended up having to drill new holes for the lower radiator support and shift it further back towards the engine. I also had to grind about 2mm out of the backside of the bumper renforcement bar, to allow safe clearance for the intercooler. Because I had to the intercooler further forward then normal I also had to frig around with the mouning brackets. I drilled a new hole in the reo bar on the drivers side, on the passenger side I redrilled a new hole in the bracket. Was a bit of a gin around took me most of saturday to get it sorted. But it turned out ok. Was going to fit the UBP at the same time but im still running a stock tune. So that can wait until I get a custom tune. Horn relocation: Trial fit showed a lot of fouling:Lack of clearance between Trans cooler and I/C:Lack or clearance between I/C and bumper reo bar:Soloution was to drill new mounting holes in the lower radiator support bracket to move it back:That gave me some clearance along with using the angle grinder on the back of the reo bar:Had to modify the I/C mounting brackets a little and drill some new holes: Now I had plenty of clearnace: All done: Now just gotta sort out the issue of the bottom of the intercooler fouling on the new Typhoon bumper bar.... Didnt see that one coming... Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-600092 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 8d Gender: Male Location: Sydney NSW Posted 24/11/07 10:32 PM Share Posted 24/11/07 10:32 PM Good job squeezing all that in Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-600093 Share on other sites More sharing options...
Gavin.K Member 288 Member For: 20y 15d Gender: Male Location: sydney Posted 26/11/07 12:24 AM Share Posted 26/11/07 12:24 AM Turn your horns around as you do not want the water getting in as this will make them not work any more.I know from experence.GK Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-600434 Share on other sites More sharing options...
mbjunior99 Member 4,359 Member For: 22y 6m 5d Gender: Male Location: Brisbane Posted 26/11/07 02:05 AM Share Posted 26/11/07 02:05 AM Well done, nice job Link to comment https://www.fordxr6turbo.com/forum/topic/39126-monza-install/page/2/#findComment-600486 Share on other sites More sharing options...
