  • Well-Hard Bangin' Member
  • Member For: 19y 1m 7d
Posted
so, I may be going stark raving mad, but it looks like one of my headlights is a little duller then the other.
anyone got the same thang happening?? or got a fix for it? can you adjust the power to them or brightness levels?
coudnt find any other posts
Cheers
Dan
  • Legacy Donating Member
  • Member For: 22y 7m 13d
Posted
It will either be the aiming is off so the angle makes it dull, or the globes are different (one may be a +50%) or the wiring is buggered or the contacts are corroded.
Unusual for there to be a corrosion or wiring problem, so look at the first 2 first.
Posted
cheers ZAP, you're always a bounty of info mate
  • New Member
  • Member For: 19y 1m 15d
Posted
Funnily enough I just adjusted mine today for the same reason, I noticed it in the reflection of the car ahead that the passenger side light was a lot weaker, it's fine now very easy to adjust.
Posted
any info on how to adjust them eddie? did you adjust the brightness or direction?
Posted
The ajustment is only for up/down or left/right.
There are 2 knobs on the back of the headlight. Read the manual as it says which one does which axis.
You cannot ajust the brightness, it is fixed to the globe type and wiring.
