25/06/07 05:09 AM25/06/07 05:09 AM #1 has anyone else had to change the three little rubber mounts that hold the cross over on mine are stuffed what are they worth I'm gessing only ford sell them
25/06/07 05:10 AM25/06/07 05:10 AM #2 one of mine is knackered and would also be interested in how much they are worth
25/06/07 05:16 AM25/06/07 05:16 AM #3 Broke one as well , haven't bother changing it as I will be giving the crossover pipe the flick sooner or later.
25/06/07 06:05 AM25/06/07 06:05 AM #4 has anyone else had to change the three little rubber mounts that hold the cross over on mine are stuffed what are they worth I'm gessing only ford sell them$20 each!Bought one a few weeks ago.
25/06/07 07:41 AM25/06/07 07:41 AM #5 they are easy to change hey, just yank the old one out and glue the new one in?
25/06/07 08:02 PM25/06/07 08:02 PM #6 Author they are easy to change hey, just yank the old one out and glue the new one in?so there not screwed in what do you glue them in with cheers
28/06/07 11:42 PM28/06/07 11:42 PM #8 just got three from ford $40Can you confirm how they actually attach?
29/06/07 12:22 AM29/06/07 12:22 AM #9 Author Can you confirm how they actually attach?not yet have to pick them up on way home will let you know tonight
29/06/07 12:23 AM29/06/07 12:23 AM #10 Can you confirm how they actually attach?10 mm ring spanner or 10 mm socket to undo the three 6mm dome nuts . The mounting units at the bottom are 6 mm studs, one screws in to the top of the engine rocker cover, and the 2nd and 3rd into the Intake Manifold. You also need to undo the hose clamps that hold the air hoses in place to be able to lift the X-over unit up.Just by looking @ the whole setup you should see what I am talking about.Good luck ! Edited 29/06/07 12:35 AM29/06/07 12:35 AM by f-wolf
