  • Member For: 20y 7m 15d
Posted
hi guys! I have a query. I bought a flash tuner with a custom tune of 10psi or 11 psi on 98 octane.the car was standard at the time but I have since got a custom exhaust fitted and was told by the place I got the flash tuner from that I shouldnt use the flash tuner with the exhaust fitted until I get upgraded injectors and fuel pump.the car has not been dynoed.is this true or what? any suggestions would be helpful
  • Iconoclast
  • Legacy Donating Member
  • Member For: 22y 1d
Posted
May run lean..... Spend the money for a dyno run for peice of mind......
  • Iconoclast
Posted
If you still have the standard cat dont worry, if you have replaced the cat you will more than likely be lean if you bought a good one....
If the custom tunes are not for your car to begin with there is a big chance they will not be right for your car particularly if you have just done the exhaust...
If you are only keeping the car for 6 months dont worry, but if you want it anf rely on it.. Get it checked,
Single power run on a dyno to log AF's should cost you 50,l no more
  • <put funny sh*t here>
  • Member For: 19y 10m 20d
Posted
My mate recently purchased a CAPA flash tuner with generic 10psi tunes on it.
Hes put it on his car and hes loving it, but im trying to get him to get it dyno'd to check the AFR just incase.
How high a priority would you guys make it, to get the car dyno'd to check the AFR on the car, provided he wants to keep it for a while.
Thanks.
  • Iconoclast
Posted
Most generic tunes are quite safe..... Like 99%
But a whole new world will open up with a custom tune
Posted
thanks guys! oh well, guess I will be selling the tuner then.
  • Member For: 21y 3m 8d
Posted
no need to sell it :w00t2: just get it on a dyno, it'll cost you no more then $100, or come to one of the dyno days it'll be around $50.. if it's safe, then you're all well and good.. if it's not, then decide whether to sell the tuner or get a tune. Either way, if you've got a full exhaust, and no edit, you'll more then likely run into overboost issues on the factory ecu anyway.. then you'll have to buy another box and get it tuned :blink:
  • Member For: 21y 3m 6d
Posted
like others have said just get it on a dyno just to check that the car isn't running too lean.. you may need a tune, you may not, but it is too hard to tell until you check the afr's..
good luck mate
