86gav 69 - PSI Donating Members 263 Member For: 19y 9m 7d Location: Gladstone QLD Posted 25/04/07 07:55 AM Share Posted 25/04/07 07:55 AM Hey all, the ltimes ive filled up my T I have it has been a right royal pain in the ass. It just keeps clickng off all the time and it takes me like 20mins to fill the bitch. It seems to only do it when filling from anywhere above the fuel light, when the car is super low on fuel it fuels up fine. Anybody else had this drama or know where I should look to fix the problem?CHeersGav Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/ Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 5m 25d Gender: Male Location: Not sure? Posted 25/04/07 09:07 AM Share Posted 25/04/07 09:07 AM Get on your back and look straight up under the rear guard. The hose that you stick the pump into may be pushed up or something? The pump clicks off when the it senses that the flow is slowing. This can be from the hose splashing it back. Other than that meh! Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525796 Share on other sites More sharing options...
FastR1Red Member 360 Member For: 20y 1m 29d Gender: Male Location: Mt Waverley Posted 25/04/07 09:09 AM Share Posted 25/04/07 09:09 AM Gav, mine did it a few times ONLY when filling up from 1 particular servo - in Ringwood. Always stops though before it's full and takes a few more clicks on slow fill to top it right up. I no longer use that servo.Theo Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525797 Share on other sites More sharing options...
davidald Me Donating Members 360 Member For: 18y 3m 3d Gender: Male Location: Adelaide Posted 25/04/07 09:40 AM Share Posted 25/04/07 09:40 AM Take it to a mechanic or Ford and tell them it's not venting properly. The fuel pump receiver hole on the xr6t is different to the XT in that there is less room around the nozzle when its inserted, so it has to vent properly. Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525809 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 17d Gender: Male Location: Sydney Posted 25/04/07 09:44 AM Share Posted 25/04/07 09:44 AM It could be a venting problem.There is a thin hose that comes out of the tank and follows the main tube up tot he filler.If this is damaged, it will cause the symtoms you describe. If it is under warranty, get Ford to do it under warranty. Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525811 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 2m 6d Gender: Male Location: Brisbane Posted 25/04/07 09:57 AM Share Posted 25/04/07 09:57 AM Do you always fill up at the same servo and bowser? Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525817 Share on other sites More sharing options...
Meggs_83 Member 114 Member For: 18y 3m Gender: Male Location: Esperance Posted 25/04/07 11:35 AM Share Posted 25/04/07 11:35 AM maybe turn the nozzle sideways, all our toyota's do the same thing when fueling up. but like it's been said it's prolly a venting problem Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525848 Share on other sites More sharing options...
JimmyXR6T04 Member 1,299 Member For: 20y 11d Location: Canberra Posted 25/04/07 11:53 PM Share Posted 25/04/07 11:53 PM I have this problem at some servos.. not all. so I've put it down to the bowser. I was told by a servo attendant that if it happens, try twisting and turning the nozzle and the surrounding equipment around the hose.. it helped a few times Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525930 Share on other sites More sharing options...
crans Member 275 Member For: 19y 1m 29d Posted 26/04/07 01:10 AM Share Posted 26/04/07 01:10 AM Mine clicks off at every servo all the time.On way to stop it is to not pull the trigger as far as it can go Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525939 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 17d Gender: Male Location: Sydney Posted 26/04/07 01:20 AM Share Posted 26/04/07 01:20 AM I have NEVER had this problem with any of my Fords.I jam the fuel cap in the handle and clean the screens while it fills. I know how many litres it will take and then go manual before it clicks off.Some cars have a fueling sweet spot that you need to find. I did full driveway service for 7 years, so I am used to putting fuel in cars. Link to comment https://www.fordxr6turbo.com/forum/topic/34474-fueling-up-dramas/#findComment-525942 Share on other sites More sharing options...
