  • Member For: 23y 9m 11d
Posted
This is quite a simple exercise.
1. Using a small screwdiver pop the switch out of the head lining.
2. Unplug the switch.
3. With small screwdrier remove the switch cover and the buttons will come out.
4. Desolder the 5 x green 1206 SMD LED's.
5. Solder in 5 x new blue 1206 SMD LED's.
6. Replace buttons and cover.
7. Plug in the wiring.
8. Snap back into head lining.
I made a slip on tool for the soldering iron to desolder the LED's. LED's are approx 150mcd.
Cheers,
Scott
  • Legacy Donating Member
  • Member For: 21y 3m 12d
Posted
Thax Scott that's awesome I will have to have a go at mine now. How long did it take you the entire process?? Do the 150mcd match the interior brightness??
Cheers
Nathan
Posted
Nathan,
It took about 30 mins from start to finish. The 150 mcd are about spot on in terms of brightness.
The tricky bit is getting the old ones out ... that's why you need to be able to heat both ends of the LED at once. If you have a look at my post in the "Illuminated Window Switch Guide" I give a link to where you can get the LED's.
Good luck!
Cheers,
Scott
  • ORSM Ford Cruisers!
  • Member For: 21y 4m 6d
Posted
Hey scott, I found that the normal blue was a little too bright and didnt match the rest of the interior. And the XR blue require more forward voltage than the switch uses. This is the same procedure on all Webatso/Holandia Sunroofs I think also.
Matt
Posted
Matt,
The blue is pretty close and the brightness is about right. They are the same as I used in the window switches. I took the punt that they would be ok in the sunroof switch ... so far so good ... the roof still works.
Cheers,
Scott
  • Member For: 23y 9m 27d
Posted
That's quite freaky - I was driving home looking at my roof last night thinking... Why the hell are they green when everything else is blue.
Could you do it for a price if I sent my switch across, I'm handly with a soldering iron, but not that handy - take it to PM if you like
