O2STOCK Legacy Donating Member 607 Member For: 21y 5d Location: Brisbane Posted 20/04/07 08:39 AM Posted 20/04/07 08:39 AM I QUOTE"OK, MY FORD PARTS REP FOUND THE COOLER FOR ME, THEY ARE OUT THERE AS THEY GET FITTED TO ALL THE COP CARS. THE NO IS BAF 7A095 AA "FACT : This is a ford cooler part numberFICTION : It is no different to the coolers fitted to T6 cars from 2002 FACT : Ford is releasing a special cooler for the 40th GTFICTION : It is no more special than one from REPCO or EQUIVILANTFICTION : The ZF Gearbox needs a special coolerFACT : Any cooler will work the Auto will not go in to limp mode (Just remember to add extra trans fluid the right type)After spending an afternoon at FMCO I am no professional but I believe what I see and I see ZF equipped cars with Trans coolers. The mechanic who looks after specifically drive train components corrected the above points, I quote.“If you are concerned he said he would fit a trans-cooler for $600.00 with warrantee or jut pick a larger one up from REPCO”Well I did my research I await the onslaught of corrections from the audience
kev302 Member 6 Member For: 19y 5m 19d Gender: Male Location: PERTH Posted 20/04/07 11:54 AM Posted 20/04/07 11:54 AM (edited) Well done, go the head of the class!It s true you can fit aftermarket trans coolers to the zf box. all ya doing plumbing some hose and tech screwing a cooler to the front of ya radiator.But why f around flex hoses that are to small to go over the existing quick clipped lines and making a nice bracket for the cooler. When ford makes one that clips on and bolts in. the hard work is done for ya. just a note the std turbo zf box has a water to oil cooler mounted under the a/c comp. the cooler that you have quoted is a air to oil cooler that includes all the fittings to go onto this cooler. I must be mistaken I thought the 4spd went through the radiator!just my 2 cents Edited 20/04/07 12:04 PM by kev302
mbjunior99 Member 4,359 Member For: 23y 8m 27d Gender: Male Location: Brisbane Posted 20/04/07 11:58 AM Posted 20/04/07 11:58 AM So are you saying that the ford ZF cooler is good or bad??
O2STOCK Legacy Donating Member 607 Member For: 21y 5d Location: Brisbane Posted 20/04/07 01:09 PM Author Posted 20/04/07 01:09 PM Well done, go the head of the class!It s true you can fit aftermarket trans coolers to the zf box. all ya doing plumbing some hose and tech screwing a cooler to the front of ya radiator.But why f around flex hoses that are to small to go over the existing quick clipped lines and making a nice bracket for the cooler. When ford makes one that clips on and bolts in. the hard work is done for ya. just a note the std turbo zf box has a water to oil cooler mounted under the a/c comp. the cooler that you have quoted is a air to oil cooler that includes all the fittings to go onto this cooler. I must be mistaken I thought the 4spd went through the radiator!just my 2 centsKevThat was your part number quoted in previous thread NOT MINE ???http://www.fordxr6turbo.com/forum/index.php?showtopic=33339It is not for the ZF as YOU have indicated it is a STD cooler that has been on the spare parts list since 2002 4SP ION WTFYou can mount this FMCO cooler if you wish to part with the extra $$$ to the FMCObut my 2C says get a larger aftermarket unit The point is you DO NOT NEED A SPECIAL COOLER as before indicated in other posts.It does not matter if the lines originally go through the radiator (Ion 4sp) or a Water / Oil cooler on the side of the block (F6 ZF) these are replaced with a larger Air to Oil cooler.So are you saying that the ford ZF cooler is good or bad?? MBThe ZF cooler is great for STD use. If you wish to fit a larger cooler (Track or strip work or just insurance) as you have noted in the previous threadhttp://www.fordxr6turbo.com/forum/index.php?showtopic=33339Then you do not need a special cooler as KEV has pointed out in the (previous thread) any trans cooler will be okYou can purchase any trans cooler and fit it but remember to refill the tranny with the correct oil
loopism Tractor Driver Member 709 Member For: 20y 7m 9d Gender: Male Location: Sydney Posted 23/04/07 12:58 AM Posted 23/04/07 12:58 AM So why would Ford not fit the upgraded cooler (heavy duty towing pack version) to cars with the ZF box? Go to the Ford website, and you can see that an upgraded cooler for the ZF trans is not available.
