  • Member For: 19y 7m 26d
Posted
Also, a better IC AND higher flowing piping will net you similar power on less boost... 300 on 15 could be 300 on 12 with a good set up
yep, that's what I want, now which cooler do I get??? :dontknow:
I wanna replace stock inlet manifold with a custom plenum and relocate the battery like the nispro setup and 350rwkw is the minimum I want to achieve.
the intercooler system seems to be the trickiest component of the whole modification process to get right...
  • 2 weeks later...
  • SUPERLAP 2011
  • Member For: 19y 6m 3d
Posted
what about the aps DR series intercooler kit, anyone know how expensive they are or how they perform?
  • 2 weeks later...
  • Inactive Members
  • Member For: 19y 5m 1d
Posted
does adding bigger intercoolers affest the air cons performance as they are blocking the radiator more?
  • I see red
  • Member For: 23y 9m 11d
Posted
APS intercoolers are pretty good but cost around $2000.
No
  • 1 month later...
  • BIGRED
  • Legacy Donating Member
  • Member For: 19y 6m 4d
Posted
I have an F6 cooler on mine....anyone know how much power they can take? and what would be the power increase from having an F6 cooler on an otherwise stock car?
Posted
very little gain and not much better than stock...
  • Member For: 20y 7m 12d
Posted
I dont agree with that Groper there have been plenty of cars with 300+rwkw with F6 coolers.
  • Member For: 20y 6m 7d
Posted (edited)
A good quality intercooler core wont, but seeing as there is no off the shelf item that is using a crap core, which is a bolt on item to this car. You will find that there is no such a problem. Usually VL turbo owners who cut down old arse truck intercooler cores and fit a 1 metre wide intercooler to the front of their car to try and save a buck and get that fully sick look get such issues.
Check my signature, I am one of them cars. They flow well but suffer dearly from heat soak after a few runs.
Edited by Fat-Tony
  • Senior Member
  • Member For: 20y 1m 17d
Posted
A stock cooler can make over 300rwklw but if you value your motor in anyway you would use it,we recommend and use Process West
CV PERFORMANCE
