  • Get on the end of it.....
  • Member For: 20y 9m 13d
Posted
Hi all I am currently running 284rwkw with the factory intercooler, the tune is already running rich if I put a wog cooler in will it make it run lean, would I have to get a re tune. some places I have rung said I would not need one. any info would be good guys :biglaugh:
  • Legacy Donating Member
  • Member For: 22y 7m 28d
Posted (edited)
fit it... take it to a dyno and pay them $50 or what ever the cost is to get a couple of runs.... check afr's etc... if all is sweet then no need for a retune :biglaugh:
only way to find out
Edited by jetute
  • Member For: 20y 4m 10d
Posted
Yes and no... The boost will go up so there's a big chance you will run leaner.
As a minimum, get it onto a dyno and do a power/afr run and if its lean have the tune sorted... there's tuners these days that dont bend you over for minor touch up tunes... few hundred should get you sorted
Posted
because I live near Rockhampton and get all the work done at power torque engines in Brendale I wonder if it will be allright for the short term or sould I really get it done
Posted
surely there is a dyno in rockhampton somewhere?????? just for a run that's all?? that way at least you will know if you need to come to brissie or not... my guess is it will be fine but you wont know for sure till you run it up on a dyno
Posted
yeh cheers for that I will have to track one down
  • Im the one and only
  • Member For: 21y 8m 22d
Posted
Mate.I was running 300rwkw on stock cooler with low afr,s.I then fitted the wog cooler and it did run a little more boost but when I checked the afr,s.All was good.
You will be right in the short term but when you can,get it checked. :roflmbo:
Posted
thanks for the advice :roflmbo:
  • Member For: 21y 15d
Posted
The ECU will correct minor variations in AFRS If in doubt before you come down put some octaine booster in to to be on the safe side. But mine with a 275 RWKW tune did not lean out after fitting the cooler.
  • Member For: 23y 8m 7d
Posted
Guess you've gotta ask yourself "Am I feeling lucky?". What's cheaper, a few $'s for a retune or a lot of $'s for an engine rebuild? You might be O.K, but are you going to sleep at nights??
Consider it to be insurance!
