January 13, 200719 yr #1 Hey guys Yestaday I went for a drive and thought I give it a little squirt so Ipush the gear stick over to PEF Mode and booted it and I heard a loud grinding noise from underneith it would only do it from 3rd to 4thso I put it back in drive and was all fine.So I put it back in PEF Mode to see if it happends again and it did it 3rd to 4th the same as the frist time a loud grinding noise I dunno if it the gearboxs mabye on it way out???it only did it 2 times and keep driving and it was fine so I dunnowhat it could be.Do you reckon mabye the gearboxs is on it's way out?its a 03 model with 110,000kms on the clock.Carlos Edited January 13, 200719 yr by Black ThundeR
January 13, 200719 yr #2 Probably.Mine made and did all different shiit.There not the best box around.If I were you id rebuild it before it goes bang
January 13, 200719 yr #3 Were you changing gears yourself? Because if you just push it to the left it won't go above 3rd.
January 13, 200719 yr #4 Hey guys Yestaday I went for a drive and thought I give it a little squirt so Ipush the gear stick over to PEF Mode and booted it and I heard a loud grinding noise from underneith it would only do it from 3rd to 4thso I put it back in drive and was all fine.So I put it back in PEF Mode to see if it happends again and it did it 3rd to 4th the same as the frist time a loud grinding noise I dunno if it the gearboxs mabye on it way out???it only did it 2 times and keep driving and it was fine so I dunnowhat it could be.Do you reckon mabye the gearboxs is on it's way out?its a 03 model with 110,000kms on the clock.Carlos ←There is really nothing mechanical which can make a grinding noise in these boxes, unless you really have some serious broken teeth, in which case it will do it in "D" as well.What you are hearing is probably hydraulic "groaning" from either the valve body or the converter.In either case, you need to think about getting your box fixed.
January 13, 200719 yr #5 Author Were you changing gears yourself? Because if you just push it to the left it won't go above 3rd.←Nar it wasnt in manual mode
January 13, 200719 yr #6 Author Hey guys Yestaday I went for a drive and thought I give it a little squirt so Ipush the gear stick over to PEF Mode and booted it and I heard a loud grinding noise from underneith it would only do it from 3rd to 4thso I put it back in drive and was all fine.So I put it back in PEF Mode to see if it happends again and it did it 3rd to 4th the same as the frist time a loud grinding noise I dunno if it the gearboxs mabye on it way out???it only did it 2 times and keep driving and it was fine so I dunnowhat it could be.Do you reckon mabye the gearboxs is on it's way out?its a 03 model with 110,000kms on the clock.Carlos ←There is really nothing mechanical which can make a grinding noise in these boxes, unless you really have some serious broken teeth, in which case it will do it in "D" as well.What you are hearing is probably hydraulic "groaning" from either the valve body or the converter.In either case, you need to think about getting your box fixed.←that's probly what iam hearing and make sence aswell since it wasnt donig it on D. and gettting the boxs fixed is something I have to do either way anyway.
