  • Member For: 20y 2m 22d
Posted (edited)
Dont worry I fully intend to only put 4 litres in. Wheteher it goes in thropugh the fill plug, or the reverse switch. I will find out tommorrow when I am under the car.
Scotty
This is from the T56 Sercice CD
Edited by 937
  • Legacy Donating Member
  • Member For: 20y 7m 18d
Posted
If you fill them from the so called filler plug you WONT get enough oil into your gearbox. You need to put in 4 litres and you can only do it from the speedo drive.
http://www.fordxr6turbo.com/forum/index.ph...e=post&id=26103
There is no speedo drive, Its your reverse light switch.... :roflmbo:
  • www.australianflag.org.au
  • Member For: 21y 2m 8d
Posted
Mate now you are confusing me.
Let me get this right.
Warm gearbox,
Drain gearbox,
Put back in drain plug,
undoe fill plug, or reverse light switch,
put 4 litres transmax Z in gearbox,
put fill plug/ reverse light switch back in,
wipe up any spills, and
finally take it for a drive.
If there are any dramas with those steps then please let me know, but that is how I see the job and how I intend to do it.
Scotty
PS I am not being a smart ass, it is that I am now getting confused and am trying to keep it nice and simple.
Posted
Cheers that is the sucker I was going to use, if I could not get enough in through the fill plug. I have printed of the TSB and had a good look at it.
Scotty
