YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 2m Gender: Male Posted 21/11/06 08:41 AM Share Posted 21/11/06 08:41 AM Hey people in the last month or so I have been having some wired things happening when starting my car.First is, when I start my car and put it into drive the throttle indercator light comes on and the car starts running like crap (blup blup blup) then I switch the car off and start it again and its fine? (this has happend 5 times in the last 2 months)Second is, also some morning's when I start the car it will idle at 1000 rpm and the car feels like it going to take off by its self.It's a bitch trying to get out of my drive way because it just wonts to take off even with my foot on the brake( lightly).But after a bit it drops down to about 600 rpm, it is really starting to trip me out, apart from that the car drives fine.Both problems are only accuring on starting the car.I have a XEDE piggyback and im wondering if that's apart of the problem?Oh yeah and it stall's every now and then aswell.(not that often but it has happend)Would a EDIT fix this problem?I went to ford and they said no fault has been registered, which is bull crap Any help idea's would be appreciated.Cheers Michael Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/ Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 9m 28d Gender: Male Location: Southern Highlands NSW Posted 21/11/06 09:28 AM Share Posted 21/11/06 09:28 AM Clean throtle body first offMy t will also idle realy high when first started of a morning. It'll gwt up to around 1200rpm.. When you initialy start your car you will also see the instant litres per hour hover around 5.1 +-. I generally start to drive my T when it goea down to about 3 litres per hour. This change also will allow enough time for your revs to drop to around 800 - 900 rpmIn other words.. Let your car warm up before you start to drive itRob Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-466950 Share on other sites More sharing options...
THEMESHMAN260 Member 155 Member For: 21y 5m 22d Posted 21/11/06 10:31 AM Share Posted 21/11/06 10:31 AM It is throttle error mine does the same and I have cleaned the throttle body out it is in the edit I have been having a lot of problems lately with my edit time to go back and see what is going on and last week I dynode the car on a different place and lost 44KW was to read 280KW some thing going on here and I do not thrash the car it is more show then anything. Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467025 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 2m Gender: Male Posted 21/11/06 10:40 AM Author Share Posted 21/11/06 10:40 AM Clean throtle body first offMy t will also idle realy high when first started of a morning. It'll gwt up to around 1200rpm.. When you initialy start your car you will also see the instant litres per hour hover around 5.1 +-. I generally start to drive my T when it goea down to about 3 litres per hour. This change also will allow enough time for your revs to drop to around 800 - 900 rpmIn other words.. Let your car warm up before you start to drive itRob ←Thanks for the reply Rob ill try that Do I just clean the barrel ? or do I have to pull it apart.Thanks again.Michael Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467034 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 9m 28d Gender: Male Location: Southern Highlands NSW Posted 21/11/06 11:01 AM Share Posted 21/11/06 11:01 AM Clean throtle body first offMy t will also idle realy high when first started of a morning. It'll gwt up to around 1200rpm.. When you initialy start your car you will also see the instant litres per hour hover around 5.1 +-. I generally start to drive my T when it goea down to about 3 litres per hour. This change also will allow enough time for your revs to drop to around 800 - 900 rpmIn other words.. Let your car warm up before you start to drive itRob ←Thanks for the reply Rob ill try that Do I just clean the barrel ? or do I have to pull it apart.Thanks again.Michael←Mate pull it right down.. A good product to use is carby cleanerAnd when you put it back together make sure you double check all your hose clams.. Wouldnt want to loose boost now would you Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467054 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 3m 13d Posted 21/11/06 11:04 AM Share Posted 21/11/06 11:04 AM Clean throtle body first offMy t will also idle realy high when first started of a morning. It'll gwt up to around 1200rpm.. When you initialy start your car you will also see the instant litres per hour hover around 5.1 +-. I generally start to drive my T when it goea down to about 3 litres per hour. This change also will allow enough time for your revs to drop to around 800 - 900 rpmIn other words.. Let your car warm up before you start to drive itRob ←Thanks for the reply Rob ill try that Do I just clean the barrel ? or do I have to pull it apart.Thanks again.Michael←Mate pull it right down.. A good product to use is carby cleanerAnd when you put it back together make sure you double check all your hose clams.. Wouldnt want to loose boost now would you ←Yeh he needs all the power he can get Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467056 Share on other sites More sharing options...
xlnt6 Donating Members 350 Member For: 20y 9m 2d Gender: Male Location: Melbourne, Victoria Posted 21/11/06 11:16 AM Share Posted 21/11/06 11:16 AM First is, when I start my car and put it into drive the throttle indercator light comes on and the car starts running like crap (blup blup blup) then I switch the car off and start it again and its fine? (this has happend 5 times in the last 2 months)This used to happen to me when I had an RDP computer. After getting edit the problem never occurred any further. Maybe it's a quirk of piggybacks ??Second is, also some morning's when I start the car it will idle at 1000 rpm and the car feels like it going to take off by its self.It's a bitch trying to get out of my drive way because it just wonts to take off even with my foot on the brake( lightly).Normal, high RPM at start up to warm up cat.But after a bit it drops down to about 600 rpm, it is really starting to trip me out, apart from that the car drives fine.Both problems are only accuring on starting the car.I have a XEDE piggyback and im wondering if that's apart of the problem?Oh yeah and it stall's every now and then aswell.(not that often but it has happend)Yeap a throttle body problem. See this post.http://www.fordxr6turbo.com/forum/index.ph...topic=26669&hl=CheersRobin. Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467071 Share on other sites More sharing options...
YPURV4 KILL,KILL,KILL,DIE,DIE,DIE, Member 2,813 Member For: 19y 2m Gender: Male Posted 21/11/06 07:22 PM Author Share Posted 21/11/06 07:22 PM Thanks Rob & Robin , I did suspect the piggyback had some thing to do with it.And to the FATS your a real funny bugger arnt you Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467171 Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 2m 12d Gender: Male Location: stanthorpe wine capital of qld. Posted 21/11/06 07:52 PM Share Posted 21/11/06 07:52 PM This is the throttle body I have been running rdp system for 2 years and it has not caused any idle issues to do with the throttle body.If you really knew how they were set up you would know the rdp and any other piggy back computor does not have any control of the throttle body.IanPS I might add that this also happens with edited cars. Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467176 Share on other sites More sharing options...
bugster70 Donating Members 1,326 Member For: 20y 2m 1d Location: Canberra Posted 22/11/06 01:35 AM Share Posted 22/11/06 01:35 AM PS I might add that this also happens with edited cars.← My car is edited and I occasionally have TPS issues too. Strangely enough, it seems very much to coincide with whether my car is warm(ish) or cold. If I start the car and I'm in a hurry to get away and I put it into reverse while it's still idling quite high, I will quite often have the TPS light come on and have those idling issues (resolved, as you said, by restarting the car). But if I let it warm up for a while and the revs drop, then I rarely have TPS issues. Go figure. Link to comment https://www.fordxr6turbo.com/forum/topic/30435-throttle-and-idle-problem/#findComment-467259 Share on other sites More sharing options...
