  • Member For: 22y 1m 24d
I want to swap the Premium Sound Head unit from a Territory which is going to be sold into my wifes Fairmont that has just has the non colour 6 stacker head unit.
I know that this is a straight swap wiring wise but does anyone know if there are there any software or security code issues that I might run into with the swap. I am just worried I may have to go to Ford to get something reset if I do the swap.
I know that this is a easy swap but if anyone has any instructions to get it in and out then that would be appreciated.
  • 4 weeks later...
  • Member For: 22y 5m
HOWEVER IT IS POSSIBLE TO SWAP THE BCM'S & MODULES SO THIS IS NOT REQUIRED.
Sorry, but this is not correct!!
The best way to do this is to get Ford or ASL Logisitics to neutralise the security setting in the ICC, and you can then install it in your Fairmont.
If you start swapping out the BEM or other modules, you are opening up a whole different can of worms, with the key needing to be re-taught to the BEM, and possibly other interface issues as well.
