  • role model
  • Member For: 19y 3m 27d
When the program is loading one LED flashes at a time, then all the lights start flashing. That when I thought the program had finished. So after the lights flash quickly does it then light up the LED of the program you selected?
once you select you map P1 P2 P3 what ever and hold done select for 3 or so sec
till the lights start to flash I think it flashes 2 by 2 then eventually all the led will start to flash fast then once that finshed one LED wil lstay on and it will be the map you pic that means it finished and turn the key of and pull the cord out.
PS: hope you dont start the car on? and just the ignition is on that's all. :spoton:
  • Replies 29
  • Member For: 20y
You should get alternate flashing of the leds as it pulls the old tune out of the ecu, then as the new tune goes in you should get the lights flashing quicker and quicker from one side to the other, when finished it should have just the program you loaded lit. If you disconnected before this you may have corrupted the tune and its off to ford for a reflash.
Check your manual and try again following the instructions exactly as written
  • role model
Step by Step
* Make sure the car is off and the keys are in the ignition switch off.
* Connect the cord from the boxs to the OBDII port
* Using the SELECT buttom select which map you want
* Then hold down PROGRAM for few sec till the LED start flashing
* Turn the Ignition key on
* Then wait till all the flashing has finsh and that one LED is on solid
* Then turn the key off and pull the cord out
* Then START the car and drive away. :spoton:
  • role model
Step by Step
Think that's right lol :spoton:
