IH8TOADS Legacy Donating Member 3,618 Member For: 21y 2m 24d Gender: Male Location: OZ Posted 04/10/06 10:30 AM Posted 04/10/06 10:30 AM I got a slight whine after about 1 hour and the clutch was slipping on the dyno. Whine is not too bad bad scares me abit.←bugger that's not good. Sounds like edit means clutch to me.
Slymeat Team Kickass Legacy Donating Member 1,926 Member For: 22y 8m 4d Gender: Male Location: Albion Park, NSW Posted 04/10/06 10:32 AM Posted 04/10/06 10:32 AM I got a slight whine after about 1 hour and the clutch was slipping on the dyno. Whine is not too bad bad scares me abit.←bugger that's not good. Sounds like edit means clutch to me.←I think 800+ Nm means clutch
markxr6t Member 476 Member For: 21y 11m 2d Location: Perth WA Posted 04/10/06 03:15 PM Posted 04/10/06 03:15 PM I'm running 238kw, T5 stock clutch 66 000kms. No problem. Ford put a new gearbox in recently and said the original clutch was fine.I do mostly drive like a Nana though.........
JimmyXR6T04 Member 1,299 Member For: 21y 3m 12d Location: Canberra Posted 04/10/06 10:05 PM Posted 04/10/06 10:05 PM I ran 250rwkw with the stock clutch and my T5... the stock clutch was cactus after about 8000km. Now I have 304rwkw and a better clutch. I do have a slight shine through the gears, but I only noticed that once I put the tranzmaxZ oil in the gearbox. So it could be due to the oil change, since then, the whine hasn't got worse at all.I have to get my clutch re-installed as its not quite right, so I'm hoping my gear changes get better when the clutch is done. Otherwise I've had no issues with the T5... still just praying it doesn't go bang. At the end of the day, it's how you want to drive the car. Drive it normally with the odd boot and I'm sure it'll last long enough. I guess there's no promises though!!
