September 9, 200620 yr #1 hey guys.the 't' has slowly developed a high pitched buzzing/whistley sort of sound when accelerating in 2nd. it seems to be coming from the centre console-gearstick area. and it only seems to happen in 2nd gear while accelerating at the lower end of the rev range. its bloody annoyingany ideas?mike.
September 9, 200620 yr #2 I'd take it to Ford Service to see what they say. Sounds like the beginning of something serious.
September 9, 200620 yr #3 does it do it on decel too?? mine has a whine when accelerating and also when decelerating.
September 10, 200620 yr #4 Author does it do it on decel too?? mine has a whine when accelerating and also when decelerating.←no not on decel. and the wierd thing is only in 2nd gear around 1500-2500 rpm. it sounds like something inside the cabin and not coming from outside. dunno will have to book with ford I guess.mike
September 10, 200620 yr #5 If its an auto and the buzzing is coming from the transmission area it may be the filter in the trans blocking up with debri,also check fluid level......auto trans service fixes this.
September 10, 200620 yr #6 Author If its an auto and the buzzing is coming from the transmission area it may be the filter in the trans blocking up with debri,also check fluid level......auto trans service fixes this.←no tis 5 spd manualmike.
September 10, 200620 yr #7 Stock or modified?Do you drive it hard?The 5 speeds were known to let go on standard cars too.Goodluck with noise
September 10, 200620 yr #8 Author Stock or modified?Do you drive it hard?The 5 speeds were known to let go on standard cars too.Goodluck with noise←I dont drive it hard. the missus putts it around. completly stock. we only just bought it as an ex telstra car.mike
September 10, 200620 yr #10 Author ah well if it is then at least its still under new car warranty. I thoiught possibly someone may have experienced the same thing.mike Edited September 10, 200620 yr by miker
