shadyxr Legacy Donating Member 132 Member For: 22y 11m 27d Location: Sydney Posted 05/09/06 07:01 AM Posted 05/09/06 07:01 AM Hi All, Had Edit done over 12 months ago and last week or two have a problem with the TC & ABS light coming on for no reason. If I reverse out of my driveway and select drive the lights come on or sometimes if I just start the car and move slightly it does it too. I did have issues with it turning off at full throttle but got around that by turning TC off when going hard. Any ideas would be appreciated. Maybe I should re-load the custom tune. Thanks in advance.
XtRmn8 570Nm @1800rpm Legacy Donating Member 2,441 Member For: 23y 14d Gender: Male Location: Perth, WA Posted 05/09/06 07:17 AM Posted 05/09/06 07:17 AM Seeing that you got your car edited 12 months ago it is highly unlikely that the edit has anything to do with your problem. Don't you think??I had the same problems and it was a faulty wheel speed sensor, used for both ABS and TC. It could be that it just needs a clean and the connections checked. Otherwise you will need it replaced. Ford can tell you which one it is by checking the errors logged in your PCM.
cobrav8 Member 1,969 Member For: 21y 6m 12d Gender: Male Location: New Zealand Posted 05/09/06 07:41 AM Posted 05/09/06 07:41 AM Flash it back to standard, then see if it does it. If nothing else, take your car to Ford standard to check.
FPV TRANNY Im the one and only Legacy Donating Member 3,557 Member For: 21y 8m 29d Gender: Male Location: In my house Posted 05/09/06 07:46 AM Posted 05/09/06 07:46 AM Seeing that you got your car edited 12 months ago it is highly unlikely that the edit has anything to do with your problem. Don't you think??I had the same problems and it was a faulty wheel speed sensor, used for both ABS and TC. It could be that it just needs a clean and the connections checked. Otherwise you will need it replaced. Ford can tell you which one it is by checking the errors logged in your PCM.←Your on to it mate.Mine did the same thing and that was the problem.Not EDIT related
crans Member 275 Member For: 20y 5m 4d Posted 07/09/06 02:32 AM Posted 07/09/06 02:32 AM My TC light comes on all the time when I rev it out in first and my back end goes out to the right. I dont have an edit, could my sensors be fu(ked aswell
Garfield Member 17 Member For: 20y 5m 18d Location: Brisbane Posted 07/09/06 03:04 AM Posted 07/09/06 03:04 AM Sometimes I question the stability of the Edit/Custom tune. I have had my T tuned by one of Australias highest regarded tuners where things like TC turning off etc is supposed to be fixed. When the tune was first done it was along with a few other issues. Every couple of weeks I have to reflash with the custom tune which fixes these issues. Within a couple of weeks these issues reappear, reflash etc etc etc!I do wonder if it these ECU's actually relearns key functions of info, which periodically need to be re-written. If this is true what other "key functions" like timing, fuel etc are also being effected!This leads back to the age old arguement piggyback v's edit. Edit is by far superior for performance, but maybe piggyback is more stable. I'm not looking for an argument or debate, just thinking allowed!
Xtreme F6 Team Xtreme Legacy Donating Member 1,680 Member For: 21y 7m 28d Gender: Male Location: Perth Posted 07/09/06 03:09 AM Posted 07/09/06 03:09 AM
poida97 Member 124 Member For: 22y 7m 7d Location: Bossley Park, NSW Posted 07/09/06 05:23 AM Posted 07/09/06 05:23 AM Seeing that you got your car edited 12 months ago it is highly unlikely that the edit has anything to do with your problem. Don't you think??I had the same problems and it was a faulty wheel speed sensor, used for both ABS and TC. It could be that it just needs a clean and the connections checked. Otherwise you will need it replaced. Ford can tell you which one it is by checking the errors logged in your PCM.←I had the same symptoms, turned out to be the same problem. wanted to charge quite a bit for it too. luckily the warranty still covered it.
dingah2 Crusty aviator Member 846 Member For: 22y 3m 17d Gender: Male Location: ACT Posted 10/09/06 08:09 AM Posted 10/09/06 08:09 AM Garfield, piggyback or Edit the PCM still learns; it's just with Edit there are sooo many more things that tuners can fiddle with wihtout truly understanding the potential outcomes of their attempts at sorcery. With Piggyback the PCM software stays as is which does in fact mean that you are far less likely to get a bad tune or any of these apparent Edit features. However, in the right hands it is possible to take the tune state further with Edit than with a piggyback.....I repeat..in the right (patient) hands.Dingah
shadyxr Legacy Donating Member 132 Member For: 22y 11m 27d Location: Sydney Posted 11/09/06 03:28 AM Author Posted 11/09/06 03:28 AM Thanks for the feedback. Put the standard tune back and same problem. Booked in to Ford. They have now advised both front wheel sensors are faulty. No warranty. Hmmm!!!
