doublek Member 333 Member For: 20y 10m 13d Location: sydney Posted 27/07/06 02:54 AM Author Share Posted 27/07/06 02:54 AM thanx for that info zap. that might be my last resort. Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413056 Share on other sites More sharing options...
doublek Member 333 Member For: 20y 10m 13d Location: sydney Posted 28/07/06 12:34 AM Author Share Posted 28/07/06 12:34 AM just a quick update. I went back to the tyre place and they rebalanced the wheel .he said that it was not balanced properly last time. he had a drive in it to check for the alignement and told me that the alignement was spot on.anyway, I hit the 80kph mark this morning to check it out and guess what.... still a slight shake.it is a very small but quite quick shake of the wheel if that makes sense.I am lost now. what could it be. I may have to take up ZAP's idea and take it to a proper place as these guys pull the wheels off and balance them separately. I may need an OCB.thanx for the replies.I will keep you guys updated Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413525 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 18d Gender: Male Location: Brisbane Posted 28/07/06 12:37 AM Share Posted 28/07/06 12:37 AM Best of luck buddy - must be frustrating the f*ck out of you by now Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413527 Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 2m 2d Gender: Male Location: Melbourne,S.E Posted 28/07/06 03:10 AM Share Posted 28/07/06 03:10 AM I had the same problem at around 80kmh and up shaking in the sterrring wheelive even change 3 sets of rims and 2 new set of tyres and still seems to shake a lilltle bit and the people that did my wheel aligments and balance did it 4 times and still could get it right, just recently I did a other wheel aligment at Bob Jane and they did a much better job and not shaking anymore just sometimes, I was also told it may be becuase of my rims 19" fusion deep dish rims and they told me becuase or the bigger dish at the back it harder to blance the wheel 100% but if it's becuase of my rims im not changeing them I lvoe these ones lolPS: make sure you get your brakes machine that help alot aswell..Carlos.. Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413603 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 22d Posted 28/07/06 03:15 AM Share Posted 28/07/06 03:15 AM mine shakes at 90km and has since new. I dont travel at that speed so makes no difference to me, im either doing 80 or 100km/hr Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413605 Share on other sites More sharing options...
shadyxr Donating Members 132 Member For: 21y 7m 4d Location: Sydney Posted 28/07/06 03:24 AM Share Posted 28/07/06 03:24 AM Mines been doing it since they replaced the diff. Have fitted new tyres and rims since & still there. Took it to Ford, said they would check balance on tail shaft, then rang & said it's not bad enough to worry about. Service tech was honest enough to suggest it might be worse if they stuffed around with it. We live to see another day. Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413606 Share on other sites More sharing options...
doublek Member 333 Member For: 20y 10m 13d Location: sydney Posted 28/07/06 03:27 AM Author Share Posted 28/07/06 03:27 AM ford have machined my brakes so all good there.to the guys that have this shake, a performance car should not have a steering wheel shake. I am trying to do everything I can to correct it. I will be going on a on car balancing machine today and see if this resolves the problemwill advise of the results tomorrow. Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413608 Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 19y 1m 22d Posted 28/07/06 03:32 AM Share Posted 28/07/06 03:32 AM ford have machined my brakes so all good there.to the guys that have this shake, a performance car should not have a steering wheel shake. I am trying to do everything I can to correct it. I will be going on a on car balancing machine today and see if this resolves the problemwill advise of the results tomorrow.←its a taxi not a performance car , try driving a jeep and then you know about shakes Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413610 Share on other sites More sharing options...
Superoo Member 340 Member For: 22y 6m 12d Gender: Male Posted 28/07/06 03:38 AM Share Posted 28/07/06 03:38 AM I had a shake in the steering and no amount of balancing/alignments would fix it.Ended up being a very small kink in the alloy rim. Only noticeable if the rim was on the front. Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413617 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 5d Gender: Male Location: OZ Posted 28/07/06 03:48 AM Share Posted 28/07/06 03:48 AM I have a slight vibration at 80km/hr.....caused by a whack against a curb. Ive had an alighnment since, swapped every tyre to different positions and still have it. When I was putting some new springs in recently I noticed that the front right wheel has a small amount of play in the steering. The left had no play as it should. I also punched the curb on the right side.... things that make you go mmmmmm. Link to comment https://www.fordxr6turbo.com/forum/topic/27182-steering-wheel-shake-80kph-not-balance-issue/page/3/#findComment-413621 Share on other sites More sharing options...
