Goobz Member 746 Member For: 21y 11m 14d Location: Sutherland Shire, Sydney Posted 15/07/06 02:54 AM Posted 15/07/06 02:54 AM Can anyone tell me what the whole setup costs?ThanksChris
DCVIN Member 224 Member For: 21y 5m 8d Location: Perth Western Australia Posted 31/07/06 07:32 AM Posted 31/07/06 07:32 AM Hey Ninka how much for parts and for you to install it for me
God666 Complete Bastard Legacy Donating Member 1,123 Member For: 22y 9m 21d Gender: Male Location: Sydney Posted 31/07/06 07:50 AM Posted 31/07/06 07:50 AM (edited) The Turbo Territory also uses an engine oil cooler. See attached doc that shows all the various bits. I assume this is very similar if not the same as the F6 (have not bothered to look as yet). Edited 31/07/06 07:53 AM by God666
stealthxr Legacy Donating Member 553 Member For: 20y 7m 19d Gender: Male Location: The Shire Sydney AUS Posted 31/07/06 08:24 AM Posted 31/07/06 08:24 AM Hi Robin,Another way, which I will be fitting with the gearbox install,Is to buy an external oil cooler, which I purchased thru Ebay for $55, Im will mount that within the LHS gaurd, run plumbing back to were the oil filter mounts, I have bought a adaptor plate from rare spares in syd that mounts between the block and filter ($59) this enable you to retain the standard oil filter, it has an inlet and outlet ports which the plumbing feeds into, this method will completly bypass the engine cooling system and I THINK will be more efficient than the FPV setup... No testing has been done as it hasn't been installed, just purchased... I will post some pics when its done..Peter..
rboksic Legacy Donating Member 514 Member For: 22y 4m 27d Posted 31/07/06 11:58 AM Posted 31/07/06 11:58 AM The Turbo Territory also uses an engine oil cooler. See attached doc that shows all the various bits. I assume this is very similar if not the same as the F6 (have not bothered to look as yet).←looks like the trans is now cooled by using a swandwitch bolck instead of the radiator
Ninka Legacy Donating Member 1,850 Member For: 23y 9m 2d Gender: Male Location: Perth, WA Posted 31/07/06 01:11 PM Posted 31/07/06 01:11 PM Hey Ninka how much for parts and for you to install it for me ←Make me an offer
xlnt6 Legacy Donating Member 350 Member For: 21y 11m 24d Gender: Male Location: Melbourne, Victoria Posted 01/08/06 11:21 AM Author Posted 01/08/06 11:21 AM Hi Robin,Another way, which I will be fitting with the gearbox install,Is to buy an external oil cooler, which I purchased thru Ebay for $55, Im will mount that within the LHS gaurd, run plumbing back to were the oil filter mounts, I have bought a adaptor plate from rare spares in syd that mounts between the block and filter ($59) this enable you to retain the standard oil filter, it has an inlet and outlet ports which the plumbing feeds into, this method will completly bypass the engine cooling system and I THINK will be more efficient than the FPV setup... No testing has been done as it hasn't been installed, just purchased... I will post some pics when its done..Peter.. Hi Peter,Thanks for the info. I have ended up getting hold of the FPV cooler, etc, and went that way due to ease of fittment. I think your system will be more efficient as it will have a much larger temperature differential, where as the water cooled system has an ambient of 80 degrees or so. I look forward to see the pics when your done.CheersRobin
