  • Gold Platinum Member
  • Member For: 22y 3m 13d
Posted
Now just make a plastic cover for your amp wires :)
  • 4 weeks later...
  • Member For: 22y 1m 1d
Posted
im with terebro an d highly recommend them, I am using exactly the same amps. the sub is the 12 inch eclipse aluminium sub which im not exactly sure on specs but its big and powerful and real punchy, the fronts that I used are from focal and the model of them is the 165 k2p. the sub I think rrp is about 500 and the focals are about 800 or so. great sounding system considering it is all used through the stock head unit
cheers matt
do I get a free slab of JD if I guessed you shopped at tonkins?
decent gear but I wouldve gone the alpine type R 15' over the eclipse.
  • Member For: 21y 2m 15d
Posted
hey trough you could have if you were right but no it was from northfield in qld and in answer to adams idea, the 12 inch sub wouldnt fit in the centre with the lump from the stock sub.
I have just recieved my new alpine vehicle hub pro and wiring kit and will hopefulle get a chance to install this weekend but ill see how I go.
Thanks
Matt
  • Legacy Donating Member
  • Member For: 20y 4m 20d
Posted
You gotta take out the stock little sub and cover... then 12s fit in easy, 15s would too but need a creative mind when making the box
