June 22, 200620 yr #1 Hi guysWas wondering if a stock XR6T or XR8 exhaust cat back would fit onto a N/A XR. And if so is there any performance gains to be had or is it just a waste of time???Thanks for your input people.CheersSteve Edited June 22, 200620 yr by Duc21
June 22, 200620 yr #3 It will fit you just have to get an adapter made at an exhaust shop, as the Turbo & XR8 exhaust is twin 2 1/4". there should be a power increase, dont know how much. You'd be better off gettin a set of extractors aswell.
June 22, 200620 yr #4 im not so sure that a N/A 4 litre 6 cyl would require an exhaust that big, you might be trading of some low end torque for high end power aswell
June 22, 200620 yr #5 Hey duc...If you have a look over at Ford Forums there is quite a few boys and girls over there with N/A BA's and from what I have read they use them to pretty good effect... from memory (and I could be wrong) but it's good for about 5-10rwkw... which is better than nothing...Jack
June 23, 200620 yr #6 I did quite a few of them when I was working at a Ford dealership.Left overs from fitting Herrods products !!Before and after dyno readings showed we picked up about 10 rwkw.If you can, I would recommend keeping the factory tip on the XR system.We did a couple with 2 small dump pipes fitted behind the bumper and it tended to "Bark" a fair bit.Average cost to have Midas do a mod to the front flange to make it fit was about $80.Hope this helps you out !!
July 5, 200620 yr #7 Would $500 be a good price for a second hand full xr6t exhaust of a car with 5000kms on it?
July 6, 200620 yr #8 Would $500 be a good price for a second hand full xr6t exhaust of a car with 5000kms on it?←ive seen them go cheaper than that, ive recently seen on ebay one for 80 dollars, one for 200, and I know some1 who has one that would be wanting to sell. is your car a sedan or a ute?
July 6, 200620 yr #9 Would $500 be a good price for a second hand full xr6t exhaust of a car with 5000kms on it?←ive seen them go cheaper than that, ive recently seen on ebay one for 80 dollars, one for 200, and I know some1 who has one that would be wanting to sell. is your car a sedan or a ute?←My car is a sedan, although it already has a twin pipes from the back of the main muffler.
July 9, 200620 yr #10 Author I picked one up with 2500klms on it for $100, so im thinkin $500 is a little on the steep side.....
