June 20, 200620 yr #11 Any of the big name ful synthetics will do.←I have a XR6T BA MKII auto. I am now using Mobil 1 Syn 5W-50. (Changed it at 20,000km) Is this ok for the car (engine/turbo etc...) as the book states 15W-40. Will I void the warranty?I don't drive the car hard all the time... I'd say about 15% of my driving is what I call hard driving.I see people here are using 0W-40, 10W-60 where as I'm using 5W-50. I'd though I'd be in the middle!What do you think guys?
June 20, 200620 yr #12 I personally wouldn't use anything less than a minimum 10W oil in Qld if that is where you are. It may be okay in winter to go down but summertime, stick with the 10W.Ask Goldie.
June 20, 200620 yr #13 I personally wouldn't use anything less than a minimum 10W oil in Qld if that is where you are. It may be okay in winter to go down but summertime, stick with the 10W.Ask Goldie.←exactly im in the same boat as what to use.. ive been using the fuchs fully synthetic 15-40 but want the next level. id like to hear what oils tuners reccomend and also what weights more importantly.im hesitant on these 0w oils.... could sum1 clarify it plz
June 20, 200620 yr #14 I personally wouldn't use anything less than a minimum 10W oil in Qld if that is where you are. It may be okay in winter to go down but summertime, stick with the 10W.Ask Goldie.←I'm in Melbourne.So guys... will using 5W-50 do any damage? Anyone who in the know here please advise. Thanks.
June 20, 200620 yr #15 I'm in Canberra using Castrol Edge 0W-40. Ford even put it in for me, no issues. That said, CBR is faaarkin cold at the mo'.I can appreciate that the 0W part of the rating = a 'thin' (or low viscosity) oil when cold, and the -40 = the thickness, or viscosity at operating temp due to all the modifiers, but what's too thick?? 60 seems a tad high?I'm seriously looking at some of that Royal Purple stuff in the future (if I switch away from Edge). They make a 15W-40 full synth, exactly what the handbook says to use (the rating that is, not the type - not using any bloody mineral here!).Unless I got Royal, I think I'll stick with Castrol Edge 0W-40 though.
June 23, 200620 yr #17 Whatever the dealer uses suites me.←basic Fuchs CFX 10/30..... F that!! nothin wrong with fuchs but its just that type is basic...
June 23, 200620 yr #18 used magnatec changed every 4 - 5000kms for first 18,000 (including 1st change at 1500 then 5000. now onto 10w60. Didn't notice any change what so ever between oils. Magnetec seemed to discolour slightly quicker...but hard to say?
June 23, 200620 yr #19 I use motul 4100 10w 40 since 3000k service I supply oil to dealer every15000k, have 104000k on it doesn,t use any oil
June 23, 200620 yr #20 Magnatec changed every 7500km←Same here. It's cheap enough and is Ford spec to change every 7500 klms and Its a must to change the oil and filter at least every 7500 klm.
