April 20, 200620 yr #1 I have had my xr6t for about a year and a half and absolutely love it. But now I have had enough of standard (the new smell's gone!!) and I am in urgent need of serious horsies! Have heard standard exhaust is good enough with high flow cat. Is this true? What ECU and cooler? PLease someone help!
April 20, 200620 yr #2 Is the car an auto?? If it is an auto I recon the ultimate combo would be!Bigger dump pipe and bigger CATValve springsInjectorsCustome tuned EditAuto trans coolerSecond intake and air filterThe above should give you a solid low 12 second car.
April 20, 200620 yr #3 I have had my xr6t for about a year and a half and absolutely love it. But now I have had enough of standard (the new smell's gone!!) and I am in urgent need of serious horsies! Have heard standard exhaust is good enough with high flow cat. Is this true? What ECU and cooler? PLease someone help!←Umm I dont know what way you want to go about it, but for a fuss free 12 sec car get yourself a Nizpro stage 2. I managed a 12.1 @ 119 with sp9000's on the back and optimax in the tank!Good luck...
April 20, 200620 yr #4 Author Ive got the 6 speed. Do you guys have any problems with reliablity once the car is modified? The car is a everydayer so I am just a little bit concerned. Nizpro kit is the one where the battery is relocated. right ? 12.1 I'd be over the moon with that!
April 21, 200620 yr #5 Ive got the 6 speed.........................12.1 I'd be over the moon with that!←Yea I think anyone with a manual XR6T would!
April 21, 200620 yr #6 I have had my xr6t for about a year and a half and absolutely love it. But now I have had enough of standard (the new smell's gone!!) and I am in urgent need of serious horsies! Have heard standard exhaust is good enough with high flow cat. Is this true? What ECU and cooler? PLease someone help!←Most important question is what state are you in?Geea.
April 21, 200620 yr #8 NSW←In that case you have a problem. There are not too many 12second 6spd manuals in NSW. The best bet would be to come on the BIG VIC WEEKEND II. Have a great time, get your car tuned at one of the 2 best tuners in the country (HPF or Nizpro) and run a 12 @ Calder or Heathcote.Geea.
April 21, 200620 yr #9 I have had my xr6t for about a year and a half and absolutely love it. But now I have had enough of standard (the new smell's gone!!) and I am in urgent need of serious horsies! Have heard standard exhaust is good enough with high flow cat. Is this true? What ECU and cooler? PLease someone help!←Most important question is what state are you in?Geea. ←standard exhaust is good for over 300rwkw with highflow cat and centre muff removed... I know cause I run this set up I also have the wog cooler (autotchinica), is $499 and has proven results
April 21, 200620 yr #10 I have had my xr6t for about a year and a half and absolutely love it. But now I have had enough of standard (the new smell's gone!!) and I am in urgent need of serious horsies! Have heard standard exhaust is good enough with high flow cat. Is this true? What ECU and cooler? PLease someone help!←Most important question is what state are you in?Geea. ←standard exhaust is good for over 300rwkw with highflow cat and centre muff removed... I know cause I run this set up I also have the wog cooler (autotchinica), is $499 and has proven results ←From what I've learned over the last couple of years the easiest/cheapest exhaust mod is just what Jet has said. Free up the cat either by gutting it or getting a good quality larger free flowing one and replacing the centre muffler with straight through pipes/hot dogs. Geea.
