  • Member For: 21y 2m 23d
Posted (edited)
Hi,
I was just wondering if anyone could tell me how to fix the alignment on my headlights? I couldn't find any screws that I would normally find on most other cars. It's a BA XR6T.
Also, can you please post some pics of stock engine bays? I am curious to see mainly the area behind the RHS headlight - the battery and power steering bottle in particular, as well as the air con unit which is at the back of the LHS. Reason being, my car had a run in with a roo a while back and I just got the car back from the beater's and the engine bay just doesn't look right.
Thanks.
Edited by Shockwave-T
  • Flower Power
  • Legacy Donating Member
  • Member For: 23y 11m 7d
Posted
There should be some black round ribbed knobs on the back of the headlights.
4 all together to adjust the H4 and H7 globes.
  • Crusty aviator
  • Member For: 22y 2m 29d
Posted
Cro:
Are two for H7s and 2 for H4s or does the whole darn thing move as a single unit and two are vertical alignment and 2 horizontal alignment?
Dingah
  • Flower Power
Posted
2 for H4 and 2 for H7.
No horizontal movement available.
  • Member For: 21y 5m 13d
Posted
I found the horizontal for both h4 & h7 can be out if the globe is not held in properly ie crooked to begin with. To get at the globes, better to loosen and tilt the battery back a bit or remove on driver's side. Same with top of air box on passenger side.
Ben
  • Crusty aviator
Posted
<{POST_SNAPBACK}>
Well, well, that's shed some light on 24 months of unsuccessful fiddling....cheers Cro.
Dingah
