ugy Donating Members 199 Member For: 19y 6m 17d Location: Auckland Posted 06/02/06 04:29 AM Share Posted 06/02/06 04:29 AM When I want to change the program on my flasher it always reverts to the F setting. For example when I programe in the P2 and start the car like they say, when I have turned the car off and back on again the light has gone off the P2 and back to the F. Should it stay on the P2 so that you know what setting it is on?There is no problem with P2 tune just that it keeps reverting to the F light every time I change the programe.I hope this makes sense. Link to comment https://www.fordxr6turbo.com/forum/topic/23171-flasher/ Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 10m 15d Location: D SHIRE! Posted 06/02/06 04:33 AM Share Posted 06/02/06 04:33 AM You only download the tune you want with the ignition turned to dash lights on and when its finished the map you have chosen that light will stay on then you turn the key off unplug the Edit then start it and you goCYA JEFF Link to comment https://www.fordxr6turbo.com/forum/topic/23171-flasher/#findComment-344885 Share on other sites More sharing options...
jordak Member 1,226 Member For: 20y 10m 28d Posted 06/02/06 04:39 AM Share Posted 06/02/06 04:39 AM When I want to change the program on my flasher it always reverts to the F setting. For example when I programe in the P2 and start the car like they say, when I have turned the car off and back on again the light has gone off the P2 and back to the F. Should it stay on the P2 so that you know what setting it is on?There is no problem with P2 tune just that it keeps reverting to the F light every time I change the programe.I hope this makes sense.<{POST_SNAPBACK}>It is normal for the flasher to revert to F. Not ideal but normal Link to comment https://www.fordxr6turbo.com/forum/topic/23171-flasher/#findComment-344887 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 6m 17d Location: Auckland Posted 06/02/06 04:45 AM Author Share Posted 06/02/06 04:45 AM You only download the tune you want with the ignition turned to dash lights on and when its finished the map you have chosen that light will stay on then you turn the key off unplug the Edit then start it and you goCYA JEFF <{POST_SNAPBACK}>Thanks Jeff, but when I have finished and done the tune that I want for instance programe P2, and say I plug it in a couple of days later to programe it to programe P1. I thought the light would stay on programe P2 so you know what programe you are on but it doesn't it keeps reverting to the F for factory light.Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/23171-flasher/#findComment-344889 Share on other sites More sharing options...
DBOSS Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car Member 3,918 Member For: 21y 10m 15d Location: D SHIRE! Posted 06/02/06 06:18 AM Share Posted 06/02/06 06:18 AM You only download the tune you want with the ignition turned to dash lights on and when its finished the map you have chosen that light will stay on then you turn the key off unplug the Edit then start it and you goCYA JEFF <{POST_SNAPBACK}>Thanks Jeff, but when I have finished and done the tune that I want for instance programe P2, and say I plug it in a couple of days later to programe it to programe P1. I thought the light would stay on programe P2 so you know what programe you are on but it doesn't it keeps reverting to the F for factory light.Thanks<{POST_SNAPBACK}>that's right that's what it does does'nt mean its running the factory program though its just the starting point Link to comment https://www.fordxr6turbo.com/forum/topic/23171-flasher/#findComment-344917 Share on other sites More sharing options...
Street Tuner Member 727 Member For: 22y 4m 13d Posted 06/02/06 06:26 AM Share Posted 06/02/06 06:26 AM Correct Boss Link to comment https://www.fordxr6turbo.com/forum/topic/23171-flasher/#findComment-344919 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 6m 17d Location: Auckland Posted 06/02/06 06:49 AM Author Share Posted 06/02/06 06:49 AM Thanks guys, appreciate your input Link to comment https://www.fordxr6turbo.com/forum/topic/23171-flasher/#findComment-344929 Share on other sites More sharing options...
