Guest mercurysteve Guests Posted 20/12/05 03:43 AM Share Posted 20/12/05 03:43 AM I have the exact (probably worse) thing happening on my front bar.The answer (from a mate who is a panel beater) although it is a work around, it works perfectly.Take off the number plate and you will see what can only be described as a plastic hollow "dick" (now don't start you guys) that goes back into the cars reo. Simply put a bolt through that once you have the bar manually lifted back into it's optimum positon and then put that number plate back on. It is near on impossible to see, even with the plates off.Good luck y'all because this problem will only get worse, he has seen a heap of them already. Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-326411 Share on other sites More sharing options...
XR06T Silver Donating Members 4,146 Member For: 19y 10m 17d Gender: Male Posted 20/12/05 04:56 AM Share Posted 20/12/05 04:56 AM cheers merc..I have noticed mine sagging a bit and will check this out!!what exactly does the bolt go into?? Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-326435 Share on other sites More sharing options...
Dannopower Donating Members 421 Member For: 19y 11m 3d Gender: Male Location: Canberra ACT Posted 20/12/05 06:56 AM Share Posted 20/12/05 06:56 AM I loosened off the fittings at the front of both front wheel arches/ inner guards, then packed some washers under the mounting bolts that fix the bumper on under the bonnet, and retightened the guard fittings. Worked for me! Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-326477 Share on other sites More sharing options...
Guest mercurysteve Guests Posted 20/12/05 11:09 AM Share Posted 20/12/05 11:09 AM Not certain as it was done for me whilst I left the car with him, pretty certain that it is the plastic reo behind the front bar, just easily went stright through apparently. the extra spacer idea sounds pretty good though, top stuff Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-326577 Share on other sites More sharing options...
EnviTurbo Member 47 Member For: 20y 7m 21d Location: South Australia Posted 22/12/05 12:43 PM Share Posted 22/12/05 12:43 PM Me too vik... you ford <{POST_SNAPBACK}>All blokes your age have sagging things Vik Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-327184 Share on other sites More sharing options...
phantomchic Just because it is, doesn't mean it should be..... Lifetime Members 14,092 Member For: 20y 7m 27d Gender: Female Location: Noosa QLD Posted 22/12/05 12:54 PM Share Posted 22/12/05 12:54 PM Me too vik... you ford <{POST_SNAPBACK}>All blokes your age have sagging things Vik <{POST_SNAPBACK}> Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-327188 Share on other sites More sharing options...
Guest Guests Posted 22/12/05 01:08 PM Share Posted 22/12/05 01:08 PM Me too vik... you ford <{POST_SNAPBACK}>All blokes your age have sagging things Vik <{POST_SNAPBACK}> <{POST_SNAPBACK}>So your jugs are as firm as they were a while back???vik...and remember,anything more than a hand full is wasted Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-327192 Share on other sites More sharing options...
phantomchic Just because it is, doesn't mean it should be..... Lifetime Members 14,092 Member For: 20y 7m 27d Gender: Female Location: Noosa QLD Posted 22/12/05 03:14 PM Share Posted 22/12/05 03:14 PM Me too vik... you ford <{POST_SNAPBACK}>All blokes your age have sagging things Vik <{POST_SNAPBACK}> <{POST_SNAPBACK}>So your jugs are as firm as they were a while back???vik...and remember,anything more than a hand full is wasted<{POST_SNAPBACK}>Not Telling..!!!! anyway YOU have the problem with the SAG all good on my Phantom Beastie...shazz Link to comment https://www.fordxr6turbo.com/forum/topic/21969-sagging-front-bar/page/3/#findComment-327198 Share on other sites More sharing options...
