December 8, 200520 yr #11 Hello Mark, the BF responses very similar to the BA except for a little more torque in off boost conditions and it comes on a little sooner, power levels are also similar. We haven’t done enough BF’s at this stage to believe that peak power is much better than a “good” BA.The ZF6 does run a separate PCM and there should be access to it around March/April 2006 in the mean time I believe it will handle your power upgrade as the 600 nm torque rating is measured as an endurance figure meaning its peak torque load will be quite a bit higher.yeah that's what I thought so, you're going to have to run 2 edits to control the engine AND the gearbox...Dave.
