  • Member For: 19y 7m 21d
I noticed a sudden drop in psi when driving my T. I don't know what it is but when I put the foot down I can definetly notice a big diference in that kick you normally get when boost kicks in. So it feels like its on lower boost.
has this happend to anyone or anyone know what it might be??? :tease:
https://www.fordxr6turbo.com/forum/topic/21622-help-no-boost/
  • - Track Bound EVO III -
  • Member For: 20y 4m 23d
Loose manifold bolts.. Where the turbo meets tha manifold??
I have one missing and 2 loose, BIG difference in power..
  • Member For: 19y 10m 20d
Still keep checkin' for ken24's dik
<{POST_SNAPBACK}>
If all your pips are tight . Start un bolting zost manifold 2 check turbo bolt my old XR6 T only had 2 bolts result had low boost.Its a *beep* of a job. :fool::sofa:
  • Member For: 20y 11m 13d
Just had this happen too - there was an e-clip fixing the wastegate actuator in place under the dump pipe - after it came loose - no boost.... a real bugger to get to, so try all your plumbing first.... good luck!!!
