November 17, 200520 yr #1 Well for the first time I am happy with the dealership here, same people but there attitude has changed, weird, anyway...Both windscreens are being replaced as the rubbers have perished, apparently its part of the screen? I do live in the NT but I avoid leaving it in direct sun where possible.Second set of new discs where fitted with new revised pads, at no charge, where last time they replaced the discs they wanted me to pay for the pads, even if I supplied the pads would still be charged fitting fee.It also appears the body has cracked causing a leak and rust in the boot near the windscreen as described in other threads, to be looked at when the windscreen gets replaced.A/C fully swamped my drivers side floor (so much if you dropped your foot on the floor it splashed), so a troublesome drain valve was removed as they continually block according to them.So now before I say anything else I might just go and check for tools under the bonnet last time I found a screwdriver.
November 20, 200520 yr #2 How refreshing to hear, a good news story. So did you find anything under the bonnet? Anything vital missing?
