NighEve Member 193 Member For: 20y 8m 13d Posted 11/11/05 10:59 PM Share Posted 11/11/05 10:59 PM Hey guysAnyone else experienced this before:XR6T ute - mods; T56 upgrade, edit, custom tune, 968s, Walbro pump, hi flow exhaust. Car has done 80K and has done about 10K on the last mods (injectors, pump, tune). Minor problems as they stood were the actuator being unable to control boost levels accurately (I have been waiting for what seems forever to get another actuator designed for higher boost; unfortunately there seems to be a part shortage through my tuner - but that is another story!).Last night, driving with mates along the Inner City Bypass driving sedately at 60km/h in forth, going down a slight hill so not acceleration. Go to reapply accelerator when road levels out, pedal is completely dead, 5 seconds later it stalls. Car will not restart, regardless of changing tunes with the SCT box, disconnecting battery for over 20 minutes and trying again several times etc. This has never happened before, only sign of it coming was that it seems in the last two weeks it has taken a spilt second longer to start the car of a morning. Also, the car has smelt fuelly (which I accounted for the fact that the actuator not operating correctly will mean there is unburnt fuel when the ECU tells the injectors to open wider thinking there is boost there which drops out of the wastegate instead?).Bottom line is that the car got towed to Ford re: road side assistance. My obvious concerns now are:- What is the problem?- Will they be able to fix it?- Once/if they learn of the mods, will they wipe their hands of it and blame these?- What are my options for rectifying the problem?Any help would be appreciatedJoel. Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/ Share on other sites More sharing options...
Guest Guests Posted 11/11/05 11:20 PM Share Posted 11/11/05 11:20 PM You look at all the fuses etcvik...sounds like could be the *beep* to me???off to ford,dont forget to re flash Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-314329 Share on other sites More sharing options...
Guest Guests Posted 11/11/05 11:23 PM Share Posted 11/11/05 11:23 PM You look at all the fuses etcvik...sounds like could be the *beep* to me???off to ford,dont forget to re flash <{POST_SNAPBACK}>WTF,I wrote puuta with one u and it gets beepedvik...WTFis going on here Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-314330 Share on other sites More sharing options...
Ford_Power Member 798 Member For: 22y 29d Posted 12/11/05 12:47 PM Share Posted 12/11/05 12:47 PM It sounds like it ma be a fault with the electronic throttle.The reason it may not start (I'm assuming the engine still cranks though) is that if the electronic throttle has a failure that is making the PCM see WOT, the engine will not start.This feature of the PCM not allowing the vehicle to start when the pedal is at WOT is to assist in clearing a "flooded" condition.Ross Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-314491 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 5d Gender: Male Location: Brisbane Posted 12/11/05 12:51 PM Share Posted 12/11/05 12:51 PM No idea buddy, but I reckon we could blame it on Dynowog Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-314494 Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 10m 10d Gender: Male Posted 12/11/05 01:13 PM Share Posted 12/11/05 01:13 PM Just done my actuator c t of a job 6 hours next time ill give it to someone to do & I will pay Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-314501 Share on other sites More sharing options...
dingah2 Crusty aviator Member 846 Member For: 20y 10m 10d Gender: Male Location: ACT Posted 12/11/05 07:11 PM Share Posted 12/11/05 07:11 PM Nigheve, you might want to PM Spoonage.Dingah Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-314529 Share on other sites More sharing options...
jetute Donating Members 4,553 Member For: 21y 2m 28d Gender: Male Location: brisbane Posted 12/11/05 10:44 PM Share Posted 12/11/05 10:44 PM trent that's a classsic nigheve... sorry to hear about the problems.... hopefully you get it fixed asap :tosser: Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-314536 Share on other sites More sharing options...
NighEve Member 193 Member For: 20y 8m 13d Posted 14/11/05 10:33 AM Author Share Posted 14/11/05 10:33 AM Ford has found the problem after their suggested many hours of work on it - dud fuel pump (Walbro aftermarket one was installed in August).Clearly this is upsetting now that I have to fit the bill for their labour and now I have to find a fuel pump capable of the mods once again (hopefully one that is more reliable then the stupid Walbro crap that has failled). Any suggestions? Link to comment https://www.fordxr6turbo.com/forum/topic/21262-possible-edit-tuning-problem/#findComment-315123 Share on other sites More sharing options...
