cqae Member 229 Member For: 22y 10m 12d Posted 27/10/05 12:30 PM Posted 27/10/05 12:30 PM Hope someone can give me some advice. I recently fitted a nokia ck-7w bluetooth phone kit to a super pursuit ute. I have installed many of these including my own with no problems. However, this one has a lot of engine noise throught the speakers when driving. It is quite loud & not good enough to leave as it is. The phone plug you usually connect to is a little different though. It actually has another plug in it that runs off somewhere, & has a piggy back so there is a usable plug for the phone. I assume this is to power up another accessory. I am thinking of putting in a noise surpressor, but am unsure if I should put it right at the phone wires?hoping one of you radio super heroes will have the answer for me.by the way, this guys super prusuit is pretty cool, but give me a T anyday!
HYPO 6 Member 31 Member For: 21y 7m 19d Posted 27/10/05 12:33 PM Posted 27/10/05 12:33 PM yep there is your problem piggy back
DaKing Member 150 Member For: 21y 10m 6d Gender: Male Location: Melbourne Posted 27/10/05 01:10 PM Posted 27/10/05 01:10 PM I have he same car kit and the same problemWhat is the solution re piggy back??Help please DaKing
ZAP No boost, no bottle, just my foot on the throttle! Legacy Donating Member 7,935 Member For: 22y 7m 4d Gender: Male Location: Sydney Posted 27/10/05 01:23 PM Posted 27/10/05 01:23 PM I have the same kit with no problems at all.I would suggest trying to get a better earth and not use the one on the fusebox. Try to find a bolt or screw that goes into the metal of the car.If that does not fix the problem, you may need to put an inline filter on your alternator
shockF6 Legacy Donating Member 478 Member For: 20y 11m 14d Location: Melbourne Posted 28/10/05 08:07 AM Posted 28/10/05 08:07 AM Hope someone can give me some advice. I recently fitted a nokia ck-7w bluetooth phone kit to a super pursuit ute. I have installed many of these including my own with no problems. However, this one has a lot of engine noise throught the speakers when driving. It is quite loud & not good enough to leave as it is. The phone plug you usually connect to is a little different though. It actually has another plug in it that runs off somewhere, & has a piggy back so there is a usable plug for the phone. I assume this is to power up another accessory. I am thinking of putting in a noise surpressor, but am unsure if I should put it right at the phone wires?hoping one of you radio super heroes will have the answer for me.by the way, this guys super prusuit is pretty cool, but give me a T anyday!the piggyback you refer to is standard on all FPV's (as far as I can tell). As for the noise, check the chasis ground strap from the engine and battery are clean and making GOOD contact (dont just buzz it out, you need to unbolt it, cleck/clean and rebolt). if this still doesnt fix the problem, then run the ground from the car kit directly to a GOOD grounding point under the dash (there are several there, one example is the silver bolt in the fuse panel).If that doesnt work then I'll eat this post
cqae Member 229 Member For: 22y 10m 12d Posted 28/10/05 12:52 PM Author Posted 28/10/05 12:52 PM mate I seriosuly hope you dont have to eat this one! This guy is not happy is 60k car isnt perfect! ford screwed him around & I dont wantto do the same! I will have another look next week & will see how it goes, I hope your suggestions fix it!
