cqae Member 229 Member For: 22y 10m 16d Posted 09/10/05 12:29 PM Posted 09/10/05 12:29 PM be very careful about bashing the rotors. The handbrake shoes can catch on a 'lip' or sometimes are just over adjusted. If this is the case & you do bash them, the clip that retains the handbrake shoes can get damaged & not hold the shoes on properly which will result in the"shhh shhh" noise that is pretty common. A slikght tap is ok, but not too hard. If in doubht, rotate the disc around until the handbrake shoe adjust is visible through the disc & adjust it off so the rotor can pull off. Count the clicks & when the new disc is on just put it back in the same place. Although sometimes new discs can be slightly different & the original adjustment may not be right, just adjust them so the shoes dont touch the discs when handbrake is off but still lock the discs up when handbrake is up!
faygun Member 389 Member For: 23y 2m 10d Gender: Male Location: Sydney Posted 09/10/05 01:44 PM Author Posted 09/10/05 01:44 PM be very careful about bashing the rotors. The handbrake shoes can catch on a 'lip' or sometimes are just over adjusted. If this is the case & you do bash them, the clip that retains the handbrake shoes can get damaged & not hold the shoes on properly which will result in the"shhh shhh" noise that is pretty common. A slikght tap is ok, but not too hard. If in doubht, rotate the disc around until the handbrake shoe adjust is visible through the disc & adjust it off so the rotor can pull off. Count the clicks & when the new disc is on just put it back in the same place. Although sometimes new discs can be slightly different & the original adjustment may not be right, just adjust them so the shoes dont touch the discs when handbrake is off but still lock the discs up when handbrake is up!<{POST_SNAPBACK}>I hope I didnt damage anything by hitting the rear disc with a hammer. I have always had that sshhh shhh noise. Hey Cqae, are you talking about that small hole within the disc that is covered by a small black plastic? you can barely see through that small thing im gonna have another look at it next weekend and I will try disconnecting it through that small hole. What exactly do I have to do? unclick it until the rear discs can come off?
faygun Member 389 Member For: 23y 2m 10d Gender: Male Location: Sydney Posted 10/10/05 03:16 AM Author Posted 10/10/05 03:16 AM smash the sh*t out of the hub area with a rubber mallet. I had to do this repeatedly and they came off eventually.<{POST_SNAPBACK}>Hey Lolly,did you have to undo the hand brake cable through that small hole within the rear discs?
doublek Member 333 Member For: 22y 2m 22d Location: sydney Posted 11/10/05 08:30 AM Posted 11/10/05 08:30 AM hey faygun I am thinking of doing just my fronts as I have a rattle which is the pads rattling in their shims. I will get the dba rotors , pads and calipers.my question is did you ever get this rattling noise over bumps with the standard brakes. if so I think you would need to change the calipers.
DaKing Member 150 Member For: 21y 10m 9d Gender: Male Location: Melbourne Posted 12/10/05 11:27 AM Posted 12/10/05 11:27 AM Hey doublekWhat is this about rattling pads?I have some damned anoying rattle when I go over bumps -but only small jarring type bumps. It sounds like a rattling shock valve or something.Do you think it is the pads?Wouldn't have thought they could make that much noise.What do you think?DaKing
doublek Member 333 Member For: 22y 2m 22d Location: sydney Posted 13/10/05 05:47 AM Posted 13/10/05 05:47 AM da king, I think you may have the same thing as me. it makes a rattling over cat eyes on the road and other cracks. I have taken it to ford and the guy told me that it is the pads rattling in their shims and replaced the shims but it has not fixed it. I am going to try another dealer and see if they can.it is so bloody annoying I need to get rid of it.one way to test is when you go over bumps put your brakes on if there is no rattle it is the dammed pads rattling around.apparantly the performance brakes do not do this and that is why I may have to get them on the fronts
faygun Member 389 Member For: 23y 2m 10d Gender: Male Location: Sydney Posted 13/10/05 06:19 AM Author Posted 13/10/05 06:19 AM hey faygun I am thinking of doing just my fronts as I have a rattle which is the pads rattling in their shims. I will get the dba rotors , pads and calipers.my question is did you ever get this rattling noise over bumps with the standard brakes. if so I think you would need to change the calipers.<{POST_SNAPBACK}>Hey doublek,I have a rattling noise but its coming from the back. I think something go to do with the suspension.I havent had much of a chance to really test the brakes yet but they seem to be better and so far thank god there is no shudder I m gonna get some photos of how the new discs look and post it this weekend.cheers.
faygun Member 389 Member For: 23y 2m 10d Gender: Male Location: Sydney Posted 13/10/05 06:21 AM Author Posted 13/10/05 06:21 AM one way to test is when you go over bumps put your brakes on if there is no rattle it is the dammed pads rattling around.<{POST_SNAPBACK}>I will try this and let you know if there is no rattle
doublek Member 333 Member For: 22y 2m 22d Location: sydney Posted 13/10/05 06:37 AM Posted 13/10/05 06:37 AM yeah let me know how you go. and are you just doing the fronts or both?
faygun Member 389 Member For: 23y 2m 10d Gender: Male Location: Sydney Posted 13/10/05 12:11 PM Author Posted 13/10/05 12:11 PM yeah let me know how you go. and are you just doing the fronts or both?<{POST_SNAPBACK}>I have already done the front last weekend and planning to do the rear on saturday. the rear ones are b**ch to come off
