shiftkits.com.au Member 29 Member For: 20y 8m 17d Posted 27/09/05 03:44 AM Share Posted 27/09/05 03:44 AM I know MSD have a tach driver, and I *think* the F.R. one operates the same...They aplify the small pulses on the coil + wire that are generated each time the coils are fired.The ECU on the BA's controls everything, theres no ignitor modules etc for the coils.We are working on a tach adapter as well as a shift light / beep module for the BA'sThe shift light / beep module will be available very soon, which will be a fully programmable shift light / beep and also has one additional adjustable output.These modules can be programmed by laptop, therefore if you want to change the trigger points, you can.The tach adapter we are designing, well im not going to tell you how it works in detail, but lets just say different to the MSD / F.R. ones, and possibly a lot more accurate as they are triggered by a sensor, not by detecting voltages. Link to comment https://www.fordxr6turbo.com/forum/topic/20193-shift-light/page/2/#findComment-298754 Share on other sites More sharing options...
envi240 Member 113 Member For: 21y 1m 28d Posted 27/09/05 03:59 AM Share Posted 27/09/05 03:59 AM be interesting to see how these shift lights look.I want to flush mount it in the dash...pls keep me informedRegards Link to comment https://www.fordxr6turbo.com/forum/topic/20193-shift-light/page/2/#findComment-298759 Share on other sites More sharing options...
veczar Gold Platinum Member Member 1,081 Member For: 21y 9d Gender: Male Location: Victoria Posted 27/09/05 04:05 AM Share Posted 27/09/05 04:05 AM Or the G-Tech's get it from the 12v line Link to comment https://www.fordxr6turbo.com/forum/topic/20193-shift-light/page/2/#findComment-298763 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 22y 2m 9d Location: Geelong Victoria Posted 27/09/05 12:13 PM Share Posted 27/09/05 12:13 PM If you raise the rev limiter via edit can you change the point where the beeps start. Link to comment https://www.fordxr6turbo.com/forum/topic/20193-shift-light/page/2/#findComment-298954 Share on other sites More sharing options...
shiftkits.com.au Member 29 Member For: 20y 8m 17d Posted 07/11/05 04:22 AM Share Posted 07/11/05 04:22 AM The shift light / beep module will be available very soon, which will be a fully programmable shift light / beep and also has one additional adjustable output.These modules can be programmed by laptop, therefore if you want to change the trigger points, you can.<{POST_SNAPBACK}>Pre-orders for the shift alert modules are being taken on our website, pricing is on there also. Link to comment https://www.fordxr6turbo.com/forum/topic/20193-shift-light/page/2/#findComment-312456 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 11m 28d Gender: Male Location: The 8th Dimension Posted 07/11/05 06:36 AM Author Share Posted 07/11/05 06:36 AM Couple of Questions. where does the module plug into, direct into the ECU in the engine bay or somewhere in the dash. As there is no RPM out I take it the EXDE shift light I have will not work so what would the best way to run an LED off the module Link to comment https://www.fordxr6turbo.com/forum/topic/20193-shift-light/page/2/#findComment-312499 Share on other sites More sharing options...
shiftkits.com.au Member 29 Member For: 20y 8m 17d Posted 08/11/05 01:52 AM Share Posted 08/11/05 01:52 AM The shift alert module gets power and ground from the fuse compartment, and one wire gets spliced into the harness at the ecu.Minimum install is 3 wires.You can add any light to our module as a shift light providing it draws less than 10 watts ( 1 amp) therefore you can use a high intensity LED (with suitable dropping resistor in line) possibly mounted in the pillar. Link to comment https://www.fordxr6turbo.com/forum/topic/20193-shift-light/page/2/#findComment-312738 Share on other sites More sharing options...
