BALLBREAKER Member 427 Member For: 19y 11m 28d Gender: Male Posted 11/09/05 01:24 AM Share Posted 11/09/05 01:24 AM Iwas told by Power ford if I I change dump pipe & the cat .No more warrenty on drive line.As they said when they scan the ecu or something like that they can tell all about your mods regardless if unichip or cappa . As they said to me youre car has 220 kwrw .I said its standard they said their comtuter or scaner said 220rwkw I said no its stock only mods is exhoust they said no way.Then I said to them why do people invest so much money on dynos.They sould cam to ford for a kw reading . He said we know all youre engine mods like fuel emmisions boost & on. Is there any guys out there that can help me.yeh I do have a large cooler &315 RWKW so were they got 220 rwkw I dont know. Link to comment https://www.fordxr6turbo.com/forum/topic/19984-true-or-not/ Share on other sites More sharing options...
mk11tute Member 446 Member For: 20y 7m 23d Location: gold coast Posted 11/09/05 02:26 AM Share Posted 11/09/05 02:26 AM I think there trying to put words in your mouth and getting you to admit to mods my dealer told me theres no way they can detect edit and that was right before they told me that they where about to fit a new auto in my car! Link to comment https://www.fordxr6turbo.com/forum/topic/19984-true-or-not/#findComment-292955 Share on other sites More sharing options...
Romulus Donating Members 1,279 Member For: 20y 5m 12d Location: Perth Posted 11/09/05 02:42 AM Share Posted 11/09/05 02:42 AM Ford should still honour the warranty on the vehicle. The parts they will not honour are the items you have replaced.I recently took my car to Centre Ford in Perth for a diff replacement. I asked them not to reflash the pcm (incase it was part of normal servicing), and told them that the car had a bigger dump pipe and cat installed, along with bigger injectors. If they reflashed it, the car would not run properly. I also took it in running my 10psi program.The service advisor had no issue with my request, they replaced the diff under warranty, and commented how well the car drove. Link to comment https://www.fordxr6turbo.com/forum/topic/19984-true-or-not/#findComment-292957 Share on other sites More sharing options...
BALLBREAKER Member 427 Member For: 19y 11m 28d Gender: Male Posted 11/09/05 01:34 PM Author Share Posted 11/09/05 01:34 PM Ford should still honour the warranty on the vehicle. The parts they will not honour are the items you have replaced.I recently took my car to Centre Ford in Perth for a diff replacement. I asked them not to reflash the pcm (incase it was part of normal servicing), and told them that the car had a bigger dump pipe and cat installed, along with bigger injectors. If they reflashed it, the car would not run properly. I also took it in running my 10psi program.The service advisor had no issue with my request, they replaced the diff under warranty, and commented how well the car drove.<{POST_SNAPBACK}>You must have better dealers on your side of town. Link to comment https://www.fordxr6turbo.com/forum/topic/19984-true-or-not/#findComment-293087 Share on other sites More sharing options...
sixfan Flaccid Member Donating Members 2,503 Member For: 22y 26d Gender: Male Location: NOONAMAH, go figure..... Posted 12/09/05 07:02 AM Share Posted 12/09/05 07:02 AM Having been down a similar path recently...They may suspect you've been naughty, but it's another thing entirly to proove it. Put the car back to standard, disconnect the batt overnight and drive it around for a bit before you go in. If they claim to be able to prove you've increased the power output of your car, ask them to show you the proof, they can't. Link to comment https://www.fordxr6turbo.com/forum/topic/19984-true-or-not/#findComment-293317 Share on other sites More sharing options...
