Max Power Member 381 Member For: 21y 1m 17d Location: MENAI, NSW Posted 29/08/05 08:08 AM Share Posted 29/08/05 08:08 AM Hi guys.Ever since I installed the Walbro GSS-341 fuel pump, I often get momentary instances of loss of fuel that lasts for about 5 secs. It normally occurs when Im cruising and just touching the throttle. There's no back firing or noticible power loss (at light throttle anyway), just the grrrr feel under foot that there's no fuel. Then all is okay.Is it a coincidence that it started happening after the Walbro install?Is it because I used the original pump filter where I shouldve used the Walbro supplied pump filter?Help! What should I do?Arthur Link to comment https://www.fordxr6turbo.com/forum/topic/19734-fuel-pump-problem-or-something-else/ Share on other sites More sharing options...
Guest Guests Posted 29/08/05 08:21 AM Share Posted 29/08/05 08:21 AM Hi guys.Ever since I installed the Walbro GSS-341 fuel pump, I often get momentary instances of loss of fuel that lasts for about 5 secs. It normally occurs when Im cruising and just touching the throttle. There's no back firing or noticible power loss (at light throttle anyway), just the grrrr feel under foot that there's no fuel. Then all is okay.Is it a coincidence that it started happening after the Walbro install?Is it because I used the original pump filter where I shouldve used the Walbro supplied pump filter?Help! What should I do?Arthur<{POST_SNAPBACK}>current draw of the walbro may be higher than stock check this first as relays some times heat up and cause this symptom similar to a circuit breaker!!! Link to comment https://www.fordxr6turbo.com/forum/topic/19734-fuel-pump-problem-or-something-else/#findComment-288434 Share on other sites More sharing options...
blueboost Member 1,204 Member For: 21y 24d Gender: Male Location: Mackay NorthQueensland Posted 29/08/05 09:59 AM Share Posted 29/08/05 09:59 AM or one of the hoses might be sucking air, does not take much of a leak to cause a problem, and it can be inconsistent,(I had that problem with mine) Link to comment https://www.fordxr6turbo.com/forum/topic/19734-fuel-pump-problem-or-something-else/#findComment-288493 Share on other sites More sharing options...
Max Power Member 381 Member For: 21y 1m 17d Location: MENAI, NSW Posted 05/09/05 11:25 AM Author Share Posted 05/09/05 11:25 AM This is still happening and its starting to worry me. Dont know what it will do to the motor if its at 5500rpm in 3rd and it happens then.The other day it also happened when bringing up 3500rpm in neutral and stationary while calibrating my G-Tech.I doubt whether there was much load in this instance and therefore a need to go to a higher rated relay. Has anyone else changed fuel pump relays when going to the walbro unit?I did swap with another same rated relay inside the fuse box incase it was faulty but the problem continues.I also checked the hoses at the fuel pump for looseness but nothing.This does have me thinking though;I didnt mark the 3 hoses for when I reattached them. 1 of them is larger than the other 2 so cant be mistaken but the other 2 can be. The large one is the main fuel feed and the other 2 are fuel returns and breathers (I guess). Theyre both black where 1 has black release clips while the other has grey clips. I might have these attached these the wrong way around and this might be the cause of the problem.Can someone please do me a favour and have a look at their fuel hoses and tell me which way the 2 smaller hoses go on the fuel pump?Thanks in advance.Arthur Link to comment https://www.fordxr6turbo.com/forum/topic/19734-fuel-pump-problem-or-something-else/#findComment-291283 Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 4m 19d Gender: Male Location: Sydney Posted 05/09/05 11:32 AM Share Posted 05/09/05 11:32 AM Sorry, I cant check my car, its 700klms away.But id be guessing that the 2 return lines that speak of, 1 would be for the charcoal cannister. When Kirsty's AU shat a fuel pump, the service dept mixed up them hoses when replacinig it, she parked it afterwards on her steepish driveway, the charcoal cannister filled up with fuel! Would it be all that hard to do a quick swap over on the lines and go for a fang? Link to comment https://www.fordxr6turbo.com/forum/topic/19734-fuel-pump-problem-or-something-else/#findComment-291288 Share on other sites More sharing options...
bcl Toughest BA Turbo Lifetime Members 3,408 Member For: 22y 5m 26d Gender: Male Location: Sydney Posted 05/09/05 12:01 PM Share Posted 05/09/05 12:01 PM Do a quick check and make sure the fuel line near the pump isn't crimping.I think xclnt6 had that problem.Brian Link to comment https://www.fordxr6turbo.com/forum/topic/19734-fuel-pump-problem-or-something-else/#findComment-291299 Share on other sites More sharing options...
rboksic Donating Members 514 Member For: 21y 1m 21d Posted 06/09/05 12:35 PM Share Posted 06/09/05 12:35 PM the white clip goes to the right side of the car.Rob Link to comment https://www.fordxr6turbo.com/forum/topic/19734-fuel-pump-problem-or-something-else/#findComment-291707 Share on other sites More sharing options...
