August 25, 200521 yr #1 has any tried these headlight bulbs if so what are they likehttp://cgi.ebay.com.au/ULTRA-XENON-WHITE-B...1QQcmdZViewItemhttp://cgi.ebay.com.au/JAPAN-H4-HYPERWHITE...1QQcmdZViewItem
August 25, 200521 yr #2 They just appear to be the standard blue tinted bulbs you can get from anywhere like supercrap or repco.Trent.
August 25, 200521 yr #4 I am getting a new set tomorrow as I need to replace one.I see the battery and airbox being removed this weekend
August 25, 200521 yr #5 Author what type are you getting and whats the cost and when fitted can you give me run down on what you thinkcheers xr6
August 25, 200521 yr #6 Get the +50 Phillips or Osram in the cool blue. It is a whiter light like a Xenon, unlike the yellow stocker items.They are about $50 from any auto store, the ebay ones are crap chinease brands that will last a short time and may be illegal due to being too blue.
August 25, 200521 yr #7 Or you could try Narva Arctic blue. They are around 44 bucks for a pair plus 8 dollars for the parkers. Nice clean white light.
August 25, 200521 yr #8 Or you could try Narva Arctic blue. They are around 44 bucks for a pair plus 8 dollars for the parkers. Nice clean white light.I had Navara blue they dont compare to the Philips+50Rob
August 25, 200521 yr #9 Yep - the great "XENON" lamps trick.For those that don't know, Xenon lamps use Xenon gas in a chamber with electrodes and no filament- similar to neon tubes. Commercially they are used to light football grounds and factories etc, and are also available in the odd Honda and BMW, Merc, etc.They require a high voltage generator to drive them, an no-one has minaturized the HV circuit enough to fit in the base of a H4 globe! So unless a globe is sold with high voltage inverter (or states it requires one) its NOT Xenon anything!!! BK
