  • Member For: 22y 11m 1d
Posted
I've seen a hose clamp carefully placed on the shock shaft to stop it from pulling itself in. Seems to work quite well and doesn't damage the shaft.
Guest Rota_Motor
  • Guests
Posted
I changed front springs, and rear leaves for that matter, on a BA XR8 ute at work.
front end is slightly different to the magna (well up to TS magna anyway) but its definitely not hard, and I just pulled the strut out by hand, and it held itself in place while I bolted the top back on.
the front struts I dont think are gas charged, so they wont push out all the way, well it seems like they arent gas anyway, and just a tip, make sure you put the top hats on so they face the right way before you release the springs - they dont like to turn once the struts are assemble,d and if not aligned correctly can be a pit of a dog to get in the car ;)
