  • Member For: 20y 10m 19d
This may have been covered but I cant find sooooo......
Not that I am saying that it should be done but in theory if one was to gut the cat would there be many advantages, If so what would they be.
And diss advantages if there is any.
Is it hard to do
Will the beast sound better
And so on
:Imwifhim:
https://www.fordxr6turbo.com/forum/topic/17488-kill-the-cat/
  • Replies 20
Popular Days
  • I don't suffer from insanity; I enjoy every minute of it
  • Member For: 22y 4m 21d
(1) A person who is the registered owner of a motor vehicle, the owner of an
unregistered motor vehicle or the driver of a motor vehicle which is used on a
highway and at the time of use-
(a) is not equipped with any device or equipment required by the
regulations to be fitted to the motor vehicle so as to prevent or
minimize pollution; or
(b) is capable of emitting into the atmosphere any matter that does not
comply with any prescribed-
(I) emission standard; or
(ii) standard of maximum permissible concentration-
for emissions-
shall be guilty of an offence. Penalty: 60 penalty units.
In Victoria, the value of a penalty unit for the financial year commencing 1 July 2004 was $102.25 (ie. up for a minimum fine of $6,135)
__________________
plus a defect notice, plus maybe (if a cat is considered a specified equipment):
Tampering or interfering with motor vehicle without just cause or excuse
70. Tampering or interfering with motor vehicle without just cause or excuse
(1A) A person must not, without just cause or excuse, tamper or interfere with
specified equipment fitted or attached to a motor vehicle.
Penalty: 25 penalty units.
(1B) In sub-section (1A), "specified equipment" means equipment of a type
specified for the purposes of this section by the Minister in a notice
published in the Government Gazette.
https://www.fordxr6turbo.com/forum/topic/17488-kill-the-cat/#findComment-251124
aniken Posted Today, 07:33 PM
All the legal stuff
Thanks I new you would do that and yes you can come through with the I told you so after I post I got a $6000.00 fine.
1.Since this is the case what is the cost of a high flow cat that gives the same performance and better sound.
2. aniken how will they actually know that it has been done ?????
Thanks to those who have allready contributed
https://www.fordxr6turbo.com/forum/topic/17488-kill-the-cat/#findComment-251136
  • loitering with intent
  • Member For: 21y 8m 22d
Is it hard to do
:idunno:
<{POST_SNAPBACK}>
Minstral as you are probably aware we have a number of alleged"cat punchers" lurking in the shadows that have partaken of this evil anti EPA mod. I am sure that they will make their contributions in good time. In the meanwhile I think a broom handle will serve you well :Imwifhim:
https://www.fordxr6turbo.com/forum/topic/17488-kill-the-cat/#findComment-251149
All the legal stuff
Well, Dr Z doesn't seem to be around anymore, so I thought someone had better take care of the legal stuff. :P Wasn't passing judgement - information is power! And mechanical stuff ain't my strong point (altough I do recall that you would have to compensate for the change in back pressure with the killed cat, so there are other costs to incur in the engine apart from the risk of fine).
How will they know? I don't know, but if the stuff about flames out the exhaust is true, you'd think that might be reason enough for a curious copper to pull you over for a look and a fiddle. If and when Victoria introduces compulsory annual emissions testing as part of rego (every State will, eventually), the fact that your cat is gone would show up in what comes out the back of the car (unless you put in back in for rego purposes, of course :Imwifhim:).
https://www.fordxr6turbo.com/forum/topic/17488-kill-the-cat/#findComment-251150
I know you wernt :idunno: I am glade to know what it might cost me if it ever was to happen.
I want to know all involved from fines to what maybe required to equalize the back pressure.
Thank you all so far keep it commin :Imwifhim:
https://www.fordxr6turbo.com/forum/topic/17488-kill-the-cat/#findComment-251155
