April 5, 200521 yr #1 Hi guys.Instead of upgrading the intercooler and risking my drivetrain warranty, I thought I might try doing the water spray mod instead. So do I do the Geea water spray mod with a pressure switch or get a water spray kit like http://www.autospeed.com/shop/category_705/browse.html or something else? As Im located in Sydney, where from and how much?Regards,Max
April 5, 200521 yr #2 I would go the Geea job, all it needs is a T pice with a tap and some home irrigation supplies, it costs peanuts and does the same job.Dazza.
April 5, 200521 yr #4 I myself plumbed in another window washer pump into the washer bottle,used a 4psi Hobbs pressure switch (p/n sw p 76583/4) $32.00 a small garden sprinkler,small lcd light wala $50.00 works a treat Greg
April 5, 200521 yr #5 Author I myself plumbed in another window washer pump into the washer bottle,used a 4psi Hobbs pressure switch (p/n sw p 76583/4) $32.00 a small garden sprinkler,small lcd light wala $50.00 works a treat Greg<{POST_SNAPBACK}>This Hobbs pressure switch looks to be what Im after. Where do you get it and the other washer pump from?Can you override it if you want to give your IC a quick squirt?Is it switchable so its only on as required?Max
April 6, 200521 yr #7 I've just setup a water spray on my ute. I used the autospeed spray nozzle & vdo pump. I put the pump into a 20L water drum in the back of the ute, & I switch it manually using the traction control switch, this can only be done in the utes, as the traction control switch does nothing!I think using a manual switch is the way to go, its simple & you know when you need it.My understanding, the intercooler is just a large heatsink, & you need to cool it down before the power run. If you use a pressure / boost switch, you're cooling the intercooler basically after you need it.You can also get cheap kits from electronic stores, where you can specify the duration of the water spray you want, & how long between sprays, but once again it's a bit hit & miss.Using the spray it does make a difference, I think it feels smoother & more consistant power, it's hard to explain.
April 6, 200521 yr #8 Well with a colder intercooler you will be generating cooler intake air, so it makes perfect sense, off the line is where an intercooler is innefective due to heatsoak, so if you can assist that you will get results.Dazza.
April 6, 200521 yr #9 Is there going to be any problems with the water over time damaging the XR6T stock IC (e.g. rusting/coroding it)? I read someone was using metho/water mix...?Also Out of a 5L bottle how long does the water last with the setups you guys have done yourelfs?I looked for a thread on your water spray mod geea couldn't find one. I'd be interested to know what you did also.
April 6, 200521 yr #10 The biggest headach with the water spray is most tracks will kick you off if you put any fluid on the track.The reason they use methanol/water mix is it gives a better cooling solution, but it is mainly used for water injection. Plain old water is fine.You will not rust the intercooler as it is alloy.They do make a difference to the intake temp.
