N SPOOL Member 7 Member For: 21y 9m 13d Location: WOLLONGONG Posted 01/03/05 08:15 AM Posted 01/03/05 08:15 AM hi all just wondering if anybody else has had the same problem as me.when my xr6t idles it has a miss.I have taken it back once and they fixed it a bit but it still does it, does anybody know how to fix it..im taking it back again but was just wondering if anybody had the same problem. its pissing me off.
BLK6T Member 305 Member For: 21y 11m 21d Gender: Male Location: Sydney NSW Posted 01/03/05 10:36 PM Posted 01/03/05 10:36 PM When I first got my T I thought the same thing but its normal their just rough when they idle. At the dealers I asked to turn on the demos to see if they idled the same and they did. Even my mates at work idles rough. I believe it has something to do with the turbo and the ecu. It has grown on me and now I like it as it feels mean. Dont worry their not as bad as the Maloos which idle very rough.
N SPOOL Member 7 Member For: 21y 9m 13d Location: WOLLONGONG Posted 02/03/05 05:30 AM Author Posted 02/03/05 05:30 AM THANKS DUDE....
loaded Member 77 Member For: 22y 8m 1d Location: sydney Posted 02/03/05 06:46 AM Posted 02/03/05 06:46 AM Yeah mine does the same thing.It feels like the car is rocking from right to left and the rev needle flickers a bit.My dealer has tried everything to fix it but the problem seems to appear again after a few days.Unlike some others my car has never stalled.It's pissing me off as well so I am wondereing if this new edit gizmo will fix the problem?Can anyone confirm if the edit will fix this.Peter
dingah2 Crusty aviator Member 846 Member For: 22y 3m 17d Gender: Male Location: ACT Posted 02/03/05 07:56 AM Posted 02/03/05 07:56 AM Normal - don't think so. Even with APR Phase 2 mine idels as steady and smooth as a straight 6 should. Have you tried the 10 second engine turnover with accelerator to the floor to reset the cams?Dingah
loaded Member 77 Member For: 22y 8m 1d Location: sydney Posted 02/03/05 08:23 AM Posted 02/03/05 08:23 AM "Quote"Normal - don't think so. Even with APR Phase 2 mine idels as steady and smooth as a straight 6 should. Have you tried the 10 second engine turnover with accelerator to the floor to reset the cams?DingahCan you please elaborate on this 10 sec thing that resets the cams.Peter
dingah2 Crusty aviator Member 846 Member For: 22y 3m 17d Gender: Male Location: ACT Posted 02/03/05 12:11 PM Posted 02/03/05 12:11 PM Sure.....holding accelerator to the floor turn engine over for at least 10 seconds then release key and right foot. Re-start engine. It certainly cleared some idling issues that I experienced early in the piece. Doesn't matter if you are facing East or West. It's not voodoo but I'd leave it to one of the technical gurus to explain exactly which part of the cam/timing in reset by this method.Dingah
Trough Lolly Member 4,349 Member For: 22y 28d Gender: Male Location: Mildura Posted 02/03/05 12:18 PM Posted 02/03/05 12:18 PM wouldnt that make the motor a bit sick? I mean it starts in like the first 2 seconds, so holding the key on for anutha 8 seconds cant be good for the starter motor!
dingah2 Crusty aviator Member 846 Member For: 22y 3m 17d Gender: Male Location: ACT Posted 02/03/05 07:09 PM Posted 02/03/05 07:09 PM You must hold my advice or Ford's design in a particularly dim view my boy.No of course it doesn't. The ECU will not allow the car to start under such conditions. Try it and be a believer.Dingah
loaded Member 77 Member For: 22y 8m 1d Location: sydney Posted 03/03/05 08:51 AM Posted 03/03/05 08:51 AM I'm a believer cause I think by holding the foot flat makes the car go into a "flood clear" mode.Thanks Dingah I will try it.Peter
