Guest blueXRT Guests Posted 10/11/04 02:50 AM Share Posted 10/11/04 02:50 AM Very strange thing happened this morning, turned the key to start and heard a large click sound the car did not start then a white smoke started to come out from under the bonnet. Lifted the bonnet and it seemed the majority of the smoke was coming from the turbo side of the engine? It lasted for about 10 seconds then cleared up, it had a burning smell?? Started the car up as I was going to the dealer for some warranty work anyway and the car ran fine? Told the dealer and he of course had no exlpanation?If anyone has had similar experiences please share Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/ Share on other sites More sharing options...
Cashie Donating Members 663 Member For: 22y 4m 21d Gender: Male Location: Perth Posted 10/11/04 04:04 AM Share Posted 10/11/04 04:04 AM Sounds like what normally happens when the pipe blows off the turbo outlet, normally the car runs like a chaff-cutter afterwards though. Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185172 Share on other sites More sharing options...
KBB Member 55 Member For: 20y 8m 26d Posted 10/11/04 06:25 AM Share Posted 10/11/04 06:25 AM very typical of an electrical short circuit I reckon Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185221 Share on other sites More sharing options...
Guest Guests Posted 10/11/04 07:00 AM Share Posted 10/11/04 07:00 AM very typical of an electrical short circuit I reckon<{POST_SNAPBACK}>yep fuseble links on that side (little square boxs under fuse cover) whats not working? Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185226 Share on other sites More sharing options...
Henry Member 180 Member For: 22y 4m 12d Gender: Not Telling Posted 10/11/04 09:57 PM Share Posted 10/11/04 09:57 PM Very very interestingI have had a similar issue on 2 occassions this year, but I get black smoke for about a minute!! Coming from around the turbo area too!!The first time it scared the sh*te out of me, I jumped out of the car and moved well away for fear it was on fire. Yep that's how much smoke we are talking here.Like you it smells like something is burning, and judging by the colour I reckon its probably oil, but it just makes no sense to me.The second time I popped the bonnet and couldnt really tell where it was coming from except from in the general area of the turbo.Both times it started after a bit of persistence, ran a bit rough for about 30 seconds then no more problems.Everything is still working on the car and I can't predict when this will happen.The dealer has no idea what the problem is, as usual. I expect that at the first service after the expiration of the warranty that I will get a phone call and an estimate for a new this and that and $2K thanx!!Anyone know if Ford will be offering the extended warranties on these contraptions? Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185471 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 11d Gender: Male Location: Newcastle Posted 10/11/04 10:15 PM Share Posted 10/11/04 10:15 PM Was this the first start of the car for that morning? If so it wouldn't be oil because nothing would be hot enough yet to burn the oil. I'd be definately looking at the electrical side of things and making sure everything works properly. The clicking sound would most probably be relays so open up the fuse/relay boxes and a have a looky. Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185474 Share on other sites More sharing options...
DallasQLD Lifetime Members 1,197 Member For: 22y 6m 12d Gender: Male Location: Albany Creek QLD Posted 10/11/04 10:26 PM Share Posted 10/11/04 10:26 PM My T did this. Search for thread on cloud of smoke. It something to do with the Engine firing and the turbo.Ford as usual could fault it and of course didnt believe me!Dallas Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185478 Share on other sites More sharing options...
Henry Member 180 Member For: 22y 4m 12d Gender: Not Telling Posted 10/11/04 11:28 PM Share Posted 10/11/04 11:28 PM For me the first time the car had been sitting for about an hour after a 10 - 15 minute run.The second time it was a first up morning start.I do seem to recall a bit of an engine sneeze on both occassions. Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185505 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 3d Gender: Male Location: Sydney Posted 10/11/04 11:39 PM Share Posted 10/11/04 11:39 PM I had a similar thing.driven the car for about 10mins, parked in the driveway and black smoke started coming from the right side of the bonet. Opened the bonnet and smelt oil smoke. Could not see where it was coming from, but I suspect it was a oil hose. This was about 2 months ago and it has not happened since. The car does not drop any oil, I can only imagin that there is some sort of pressure relief valve for oil and coolant. You may have popped the coolant valve. I do not know for certain that this is the case, but usually if something leaks, it will continue to leak and not just do a once off.Its a bit of a worry that several people have reported this. Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185511 Share on other sites More sharing options...
rusht Member 198 Member For: 20y 11m 16d Posted 11/11/04 12:48 AM Share Posted 11/11/04 12:48 AM Anyone know if Ford will be offering the extended warranties on these contraptions?<{POST_SNAPBACK}>Yeah they are, but shop around. I found $600 difference in price between dealers for an extra 3 yrs/60,000 km. Link to comment https://www.fordxr6turbo.com/forum/topic/13883-engine-smoke/#findComment-185543 Share on other sites More sharing options...
