Guest BOOSTED Guests Posted 28/10/04 03:22 AM Posted 28/10/04 03:22 AM hows it going guys/galsjust put a exshaut on my xr6t utedump pipe back , 3 1/2 inch no middle muffler just a straight though rear mufflerit goes allot harder but now its back fireing crazythe engine is no cutting outonly when u cruise itcan any one help plz?
KBB Member 55 Member For: 22y 13d Posted 28/10/04 04:10 AM Posted 28/10/04 04:10 AM when you are trailling the throttle right, ie just touching it or backing off after a bootful??You either have a laek in a flange somewhere and fresh oxygen is mixing with hot exh gasses, BOOM or if the system is straight thru enough fresh oxygen will make its way up the tail pipe to the hotter gas coming down and mix and explode
Guest Guests Posted 28/10/04 03:14 PM Posted 28/10/04 03:14 PM when you are trailling the throttle right, ie just touching it or backing off after a bootful??You either have a laek in a flange somewhere and fresh oxygen is mixing with hot exh gasses, BOOM or if the system is straight thru enough fresh oxygen will make its way up the tail pipe to the hotter gas coming down and mix and explode<{POST_SNAPBACK}>
Lawsy Wanabe mechanical engineer Legacy Donating Member 960 Member For: 22y 18d Gender: Male Location: At the computer, obviously..... Posted 28/10/04 10:34 PM Posted 28/10/04 10:34 PM Bit of trail off sounds awesome on the t's though (not as good as on the 8's but meh...).
Blown BA In Your Face Member 6,195 Member For: 23y 6m 26d Gender: Male Location: Peninsula Posted 29/10/04 06:21 AM Posted 29/10/04 06:21 AM when you are trailling the throttle right, ie just touching it or backing off after a bootful??You either have a laek in a flange somewhere and fresh oxygen is mixing with hot exh gasses, BOOM or if the system is straight thru enough fresh oxygen will make its way up the tail pipe to the hotter gas coming down and mix and explode<{POST_SNAPBACK}>Good info there KBB
