Guest rabbit Guests Posted 12/05/04 12:24 AM Posted 12/05/04 12:24 AM Anyone able to tell me how you remove the centre stack that holds the radio, air con etc? I need to install a car kit.
Guest Guests Posted 12/05/04 12:49 AM Posted 12/05/04 12:49 AM Its easy,get in drivres seat,make sure your comfy,now start the car and drive it to a mobb that know what they are doing,much less head watsanames.vik
cqae Member 229 Member For: 22y 11m 3d Posted 12/05/04 03:24 AM Posted 12/05/04 03:24 AM is actually pretty easy, remove the top cover where the fairmont has clock. you do this by clipping it up from the very front of the panelthen you remove the side panels so you can get the part out where the tissues are.the ICC has about 6 8mm head bolts that hold it in, then it just pulls straight back.IMPORTANT NOTE!do not tip ICC over or upside down or it will fall apart inside!if you need further details, let me know & I will type a more detailed explanation
cqae Member 229 Member For: 22y 11m 3d Posted 12/05/04 03:26 AM Posted 12/05/04 03:26 AM another important thing to mention:when the ICC comes out, the plugs at the back sort of release. Make sure they are fully released & open before you refit the ICC or they will get broken when you push it back & then you car wont go!!one question though, why pull out the ICC, the plugs for the mobile phone kit are behind the fuse box!
Turbo6man Legacy Donating Member 4,084 Member For: 23y 11m 28d Gender: Male Location: South Coast NSW Posted 12/05/04 09:49 AM Posted 12/05/04 09:49 AM IMPORTANT NOTE!do not tip ICC over or upside down or it will fall apart inside!Are you trying to tell me that if I roll my XR onto it's roof that the ICC will have to be replaced!! Damm Another case of the AU being better - mine rolled over and nothing fell out - not even the missus
Worpor Member 467 Member For: 22y 7m 23d Location: Perth Posted 12/05/04 09:57 AM Posted 12/05/04 09:57 AM Man just fork out the 120 and let someone else have the grief.
GlennAUII Former XT pilot Legacy Donating Member 4,791 Member For: 23y 2m 15d Gender: Male Location: The Womb Posted 12/05/04 10:07 AM Posted 12/05/04 10:07 AM 1. remove gear lever surround (not the silver, the grey bit)2. theres 2 screws to remove the banana shaped arm things on the side, uno em, and pull em off.3. Take the tissue thing out, theres a screw either side.4. undo the bolts on the side of the icc.5. remove the fairmont clock cover, and theres a screw or bolt in there. As said, DON'T TILT THE ICC :D
Guest 56Mainline Guests Posted 18/05/04 08:05 AM Posted 18/05/04 08:05 AM If you remove the ICC or even undo the bolts that hold it into place, then something happens to the ICC that requires it to be replaced, you will have voided warrenty on the ICC.Ford is being very hard on ICC warrenty claims...if they even suspect that you have tampered in any way with the ICC, they void it's warrenty.Be real careful!
ms700 Moderating Team 10,170 Member For: 23y 8m 7d Gender: Male Location: Sydney Posted 18/05/04 08:24 AM Posted 18/05/04 08:24 AM If you are installing a car kit (I assume a mobile phone), why dont you use the genuine Ford phone presenter? That way no extra holes are drilled into the dash.....I had to laugh, when the BA's were first released, the local auto leccy mob were installing a handsfree kit into a BA, drilled 2 holes in the side of the dash to mount the phone holder, accidentally drilled too far, drilled thru the ICC, 3k later, new ICC!
